Beyond the P0700 code
Old 06 May 2009, 03:11 am
Default Beyond the P0700 code
My 2001 PT Cruiser w/ auto has the following:
P1684 Driver 5 Line 4
P0700 Transmission Control System Malfunction
In searching other posts I see this has happened to other owners. Is there such a thing as a common problem, or typical failure that sends off this code. I am on a limited budget and the local dealer wants $145 to run and breakdown the code.
I usually try to fix things myself. Locking an owner into a forced dealer visit isn't nice! Thanks in advance for any feedback. I search prior posts, and could not come up with any consensus other than transmission problems somewhere..
Old 06 May 2009, 04:26 am
Default Re: Beyond the P0700 code
mAYBE THESE WILL HELP....
Error Code 0700 on my 2001 PTC
P0700 Error Code On PT
'02 Limited edition Automatic transmission woes
Tranny Problems
NEED CODE ANSWER
Old 06 May 2009, 05:46 am
Why go to a dealer?
Why not a qualified/trained/certified independant repair shop?
As a shop owner, I have the same Chrysler scan tools and repair information as a dealership. My cost for the same testing you were quoted $145 is $47.38.
Old 06 May 2009, 04:47 pm
Thanks for the feedback.
Great PT Forum. I did search for most of what Crewzin provided regarding Error Codes before I posted my questions.
And thanks for the heads-ups on the private repairs shops.
Just around the corner Kelly’s Auto in Costa Mesa ran the tests for $70.00 with repair credit going toward parts.
A further diagnosis with the computer was showing a P0605.
Basically the TCM took a dump and needs to be replaced. Thank god the tranny is still sound. It was replaced at 64K, and we now have 110,500. I should be back on the road for under $500.00.
Now if I can just stop that squeaking in the belt area!
P0700 Error Code On PT Floyd Harris Tech & Performance Forum 4 29 Dec 2011 01:25 pm
the dreaded p0551 code - stumper djfox1 Turbo Performance 9 27 Jun 2011 03:31 pm
Code 2094 Camshaft Position Actuator bank 2 low PTGUY_PSL Tech & Performance Forum 0 27 Dec 2008 08:46 pm
Error code trouble P0132, 1686, 1687, 1681 SolidusGorto General PT Cruiser Discussions 0 19 Jun 2008 07:59 am
Dark Plum paint code ChaosTheory The Detail Shop 3 18 Mar 2008 11:03 pm
