locked doors
Old 07 May 2009, 07:53 pm
Default locked doors
I recently took my '03 PT out of a 1 year storage. While not being used the car sat w/ the doors locked. When I went to use it the rear doors will not unlock, the buttons go up & down w/ the switch but still will not open. I pulled up the buttons, still won't open. I tried pulling the buttons up & down w/ needle nose pliers nothing. Any suggestions? Pulling the door panels off w/ the doors locked & closed would probably be diffacult. -Thanks
Old 07 May 2009, 10:47 pm
Decsr's Avatar
Default Re: locked doors
If the locks will pull up by hand then the doors should be unlocked. Try pouring hot tap water in the top of the door channel because the rubber door seal might be stuck to the inside frame, then pull like heck.
This PT Convertible use to be my BABY it was a 2005 Base 5 speed, Black on black on black, Red rims with full moons hubcaps, Amber fog lights, 6 disc indash CD, Polk speakers, Suicide knob, Black 15" spring ant., Gauges in console, APC air filter system, Complete bullet/turbo exhaust system, Hurst Shifter. May its new owner enjoy it as much as we did. We do still have a 2007 Limiter PT in Cool Vanilla with no mods and two HHRs now.
Old 10 May 2009, 07:14 am
The doors are not stuck, they are locked. Pushing the button (on the outside door handle) it is as if they are disconnected fron the mechinism in the latch.
Old 10 May 2009, 08:44 am
oldcoach's Avatar
IF you un-lock the doors with the button have you tried to then open the door from the outside?
02' Black Woodie Limited Edition Drop in K&N Air Filter w/air box mod. 06 tail lights, Limo tint all around, orange LED interior, Mopar 8 inch sub, Stull side pipes. Silver stars upfront, a little chrome
Old 10 May 2009, 12:08 pm
Yes with the rear side windows down, pulling up on the lock button,using the outside door handle (as well trying the inside handle), the doors still will not open.
Old 10 May 2009, 12:13 pm
Around here we have a door lock service that will come to your house and work on your doors, you may want to check your area for something like that.
Good luck!!!
Old 17 May 2009, 04:35 pm
Talking Re: locked doors
Problem solved, the locks were just plain stuck. I removed the door panels (they do come out w/ the doors closed). I then shot white spray lithium grease into the latch mechanism then forced the lock rod back & forth, then it finally unlocked. The other side was more stubborn. After getting the door open it would not latch. I had to unbolt the latch mechanism and lube it up. It now works w/ the only problem being the child lock being stuck on. I can live w/ that. Thanks to all who took the time to respond.
PT Doors she_so Exterior Accessories Forum 6 16 Mar 2009 09:26 pm
2004 PT Cruiser doors will not unlock KarenC General PT Cruiser Discussions 9 07 Feb 2009 01:02 pm
Doors lock & unlock for no reason molnar441 General PT Cruiser Discussions 3 01 Oct 2008 02:12 pm
Doors lock & unlock for no reason molnar441 Tech & Performance Forum 2 20 Aug 2008 03:18 pm
Suicide Doors SwtNLwPT Exterior Accessories Forum 6 22 Feb 2004 10:18 am
