PT Cruiser Forum Car Videos
Custom Wheels
overheating
  #41 (permalink)
Old 09 Jul 2008, 09:22 pm
msjules msjules is offline
Send a message via AIM to msjules
Default Re: overheating
Originally Posted by CREWZIN View Post
Yes, if you've checked out the other threads about overheating, there's a number of reasons why your PT could be overheating. You said you told them to check the fuse and fan ....did they say both speeds of the motor are working, the fuse and relays are OK? Are you loosing water at all, a blown head gasket will do that and cause overheating.
Since your at 120K, was the major service to the timing belt and water pump and tensioner done?
The timing belt and water pump were replaced last year at about 95,000 miles
  #42 (permalink)
Old 09 Jul 2008, 09:25 pm
CREWZIN CREWZIN is offline
Originally Posted by msjules View Post
What year is your cruiser and have you had any major work to do on your auto?
Me? Why do you ask?
It's a 2001, born on date of September 2000. 94K on the odometer right now. Replacing the fan, repaired the Camshaft wiring harness and replaced the power steering pump were the only major repairs. About to do the timing belt, water pump and tensioner at 100K.
2000 PT. 95K miles, Original Owner
  #43 (permalink)
thanks
  #44 (permalink)
Old 09 Jul 2008, 09:28 pm
Me? Why do you ask?
I was just wondering if this tends to be a problem with the cruiser. At least you have less miles then me. I purchase mine in October of 2000
  #45 (permalink)
Your welcome. Good Luck.
  #46 (permalink)
Old 09 Jul 2008, 09:32 pm
I have three cars, otherwise the miles on the PT would be nearing 200,000. The overheating is a problem with PT's for some reason according to all the threads I'm seeing on this and other PT forums. All the parts that could cause overheating seem to go bad at one time or another but I'd say the fan motor is probably the worst of the lot.
  #47 (permalink)
Old 09 Jul 2008, 09:33 pm
Thank you for the info. Have a great week.
  #48 (permalink)
Old 09 Jul 2008, 09:35 pm
OK, again Good luck.
  #49 (permalink)
Old 03 Aug 2008, 12:40 am
treyle treyle is offline
2007 PT Cruiser I bought last October with 27,000 miles on it. It overheated in winter time, on the highway. Stopped and added a little coolant. It happened again, in August 2008. Same thing, very little loss of coolant, but you could smell it. It's at Chrysler and they can't figure out where the leak is coming from but they can smell the coolant when driving it. While I was there, another PT with the same problem came in. Is this a problem with PT's? They are about to tear it down on Monday, so please help!
  #50 (permalink)
Old 03 Aug 2008, 06:40 am
Welcome treyle.
I'm curious as to why you came here now when the cars already in the shop waiting to be torn down.
Anyway, found this in a search. It's not for a PT but the process is the same.........
Q: I can smell coolant inside my 1998 Neon when the defroster is on. The dealer pressure-tested the system and then ran some dye through it but couldn’t find a leak. What could be causing this problem?
A: The ominous sweet smell of coolant inside a car usually means that either the heater core or its hoses are leaking. As the ultraviolet-sensitive dye used to reveal leaks didn’t appear and you don’t mention a decline in coolant level, the leak probably is the diabolical kind that oozes enough coolant to be smelled but not enough to drip from the heater housing so it can be seen or felt. You may have to dig for this one by removing the heater core housing and anything else in the way.
vB code is On
Overheating / A/C problem xyster Tech & Performance Forum 1 09 Aug 2005 07:40 am
I think my tranny's about to go! TaylorMade Tech & Performance Forum 25 01 Apr 2005 12:46 pm
Is this overheating? MEXICANPT Turbo Performance 6 31 May 2004 06:32 pm
Spark Plugs mcruz Tech & Performance Forum 19 26 Apr 2004 10:28 am
OVERHEATING!!!!!! spidy134 General Turbo Discussions 12 09 Oct 2003 10:35 pm
  The Best Myspace Layouts | Internet Advertising | Personal Loans | MPAA | Loans
