I have a 2005 PT cruiser with only 18000 miles on it. The check engine light came on the first time with 15000 miles on it and the service department replaced the cam sensor. The problem went away until this week. I had to have the car towed into the dealer as it lurched for lack of a better term when pressing the accelerator. The service department said it was the cam sensor again and told me I needed to have a fuel and air induction service done because that was causing the problem. I'm pretty sure that the induction services weren't really necessary at this point, but followed their advice. They did all that and the problem was still there. Then they determined that the crank sensor was shorting out the cam sensor so that was replaced. Two days later I'm having the same problem and the car will once again be towed into the Chrysler service department tomorrow. Has anyone had this type of problem? I would appreciate any advice anyone has on solving this problem. Thanks!!!
Thanks. I did think the service department was trying to get more money out of me when they told me the fuel and air induction service could be causing the problem with the cam sensor. I just followed their recommendations. Unfortunately, the engine light is on and the car won't run so I have to take it back to them again today. They have replaced the cam and crank sensor, but the car is still doing the same thing...bucking or lurching when you press on the accelerator. Do you have any ideas of what could be wrong?
Vicky,
Do you know how to pull the codes stored in the computer or did they tell you which codes were found? Major causes of your problem could be a bad fuel injector or one of the plugs or wires malfunctioning. Lastly, you might have a loose or cut hose somewhere.
![]() ...just CREWZIN along! ® . . . PT Cruiser Links Moderator ![]() 2000 PT. Original Owner, 110,000 miles MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a Garage. Visit My Home Page www.CREWZIN.com Last edited by CREWZIN; 14 May 2009 at 07:56 am. |
Thanks for the help. Another person in the forum suggested turning the car on and off again a few times and I tried that, but no codes showed up on mine. The car is currently at the Chrysler dealer so I'm waiting to see what they tell me today.
Not sure, but those sensors should have been covered by EPA warranty to at least 50,000 miles. Sounds like someone is throwing parts at a problem and crossing their fingers. You might try a reputable service center if this keeps causing you $$$$'s. Good Luck!!!! Codes would help us diagnose the problem.
![]() 2008 Silver Steel Metallic, Touring, NA, Sirius; Chromed door handles; lower grille; fog light surrounds; chrome front & rear bumpers strips; Airaid air filter; Bassani duals; Modesty Cover; Autolite AP5263 Platinum Plugs (.040); Crane Plug Wires; NAPA Ceramic pads; Blane hood struts; PTeazer Gas, Brake & Foot Rest Pedals, '05 Rear Step Pad, Stainless Door Sills, Llumar tint, "A" Piller chrome; APC Strut Bar |
Turn key to "on" - but do not start engine (not "start") back one click to "off". On Off On codes may appear, followed by done, but you always get "done" - with or without codes.
Thanks. I didn't turn the ignition all the way to start, but did do the on, off, on, off, on, off and nothing came up.
I should add that this problem started last October and at that time the code was 0340. The cam sensor was replaced at that time and the car only had 15,178 miles on it. Now the problem has reared its ugly head again and the car has 18,319 miles. The original code was PO344 and both the cam and crank sensor was replaced last Monday. It ran for two days and the engine light came back on. Car went back to the service department last Thursday and this time they cleaned the connector at the pcm and the cam sensor. It ran great until this evening and once again the engine light is on and it is lurching or surging. Of course the service department is closed until Monday and I plan on taking it back in once again. Does anyone know what the mechanics should be doing to fix the problemor have any ideas what could be going on with the car? I just don't know what to tell them. Well maybe I do, but I guess I shouldn't. Anyway any advice would be appreciated. Thanks!!! |
Just wanted to add that my car has been at the service department all week and they have determined that my PCM needs to be replaced. I know that is covered under the extended warranty. I'm hoping to get the car back tomorrow and will let you know if the problem is solved. I did ask about the wiring harness and they said it was good. We'll see.......
Are you saying that this is the way to get a code to show up without plugging it into a computer? If so, where does this code appear?
RNCRUZR 1990 Toyota Pick-up 1990 Mazda Miata "Tokyo Tessie"1994 Mazda Miata ![]() 1997 Mazda Miata RIP ![]() 2001 Toyota Tacoma 2001 POS Cruiser
| "Check Engine" idiot light on AGAIN | tezz | General Turbo Discussions | 15 | 23 Jul 2010 06:09 am |
| Check engine light, skipping | ab1 | Tech & Performance Forum | 2 | 02 Aug 2008 11:13 pm |
| Check Engine Light | CHROMEDCRUISER | General PT Cruiser Discussions | 11 | 16 Jul 2008 11:46 pm |
| 06 turbo check engine light | 06SilverTurbo | Tech & Performance Forum | 23 | 21 May 2008 02:20 pm |
| Check engine oil light question | AaronR | General PT Cruiser Discussions | 5 | 28 Aug 2004 03:18 am |
