Back with another over-heating prob...
Old 15 May 2009, 04:23 pm
Default Back with another over-heating prob...
Back in August of last year, I had to replace the thermostat in my PT. Went for a little ride. First 10 or so miles, everything was fine. Ran a few miles more and noticed the temp gauge was showing hotter than normal. Few miles later, got just a little hotter and kept getting hotter, a little at a time, but didn't get into the red. I noticed that the temp would go down just a little when I hit the brakes. Temp sensor? Something easy and inexpensive?
Old 15 May 2009, 05:38 pm
Default Re: Back with another over-heating prob...
Not enough information. Are you running the A/C? Is the fan ON when the A/C is on even at idle and when you first start it up in the morning? Are you using any water? Is there hot air in the cabin if you switch the control over to heat? Hw is the overheating when you come to a stop and idle for a few minutes?
PT Overheating at idle
Old 24 May 2009, 03:56 pm
Yes, I did have the A/C on at the time. Tried to fill the water up when we got back home, but I wasn't able to put in much before it overflowed.
I have good heat, but that's when it was running normal temp. If that makes sense. Kinda gun-shy after thinking I actually fixed it, only to have it go bad a few months later. I haven't had it out much, only to Wal-Mart, which is about 5 miles from my place.
2002 PT Intermittent Starting Problems, Very Long, Goes Back 3 Years BeBeCroozer Tech & Performance Forum 21 11 Jul 2011 09:30 am
Bell crank Back order steelheep General PT Cruiser Discussions 0 02 Dec 2008 09:58 pm
FLOW BACK CATCH CAN littleblueGT Turbo Performance 4 03 Sep 2006 02:18 pm
better put your back seats back Ctown General PT Cruiser Discussions 0 26 Feb 2006 11:21 pm
Back power window switches not working lumofny Tech & Performance Forum 3 16 Jan 2005 10:00 pm
