I took the wifeys 02' PT limited 127k miles,up to the local shop and had them put in a new timing belt, idlers, drive belts, and water pump. The guy said he found a vac hose broke he replaced.
( After ) picking the car up when in drive at idle or just park idle the engine shakes, more noticeable in gear. When you give it gas and go the car has plenty of power and runs fine. It idled fine b4 the above work was done. I thought maybe it needed a tune-up so i put in new plugs and wires and no change. It did need a tune up though, the plugs looked pretty bad. It looks like they disconnected the battery cuz the clock time is wrong. Does the computer have to reset itself ? I stopped by autozone and they checked for codes and none found Any Ideas what could have happened ?????
2001 PT Limited |
According to what I can find on a search, it sounds like they didn't align the timing marks up correctly. Here's one I pulled up for you from another forum...
The timing marks don't line up - PT Forums - The PT Cruiser Enthusiasts and Owners Resource
thanks crewzin, i think your right. This is gonna be a pain. the guy at the shop is kinda hard to deal with and i know he's not gonna believe me when i say the timing marks arent lined up
2001 PT Limited |
You can do a Google search as I did with the search: "pt cruiser rough idle after timing belt change" and see all the responses.
mine did the same thing after the shop replaced the timing belt, but before i picked it up from the shop the mechanic called me and ask if the car idled rough before, i told him no that the timing belt replacement was only for maintenance, he ended up taking it back apart and found the timing mark was off one tooth.
With out feeling the vibration it's hard to diagnose but timing being off is very likely. Usually though it will run like crap and have no power.
Is it that the engine idles and chugs or is it just that you feel more vibration? If so then they may not have installed the motor mounts correctly. |
FYI:
well got it back from the shop today and you guys nailed it, thats what it was the timing belt was off a tooth or two, shes running perfect now. thanks everyone !! for your help !!
2001 PT Limited |
It's very easy to do! I do them for a living and still get it off about 30 percent of the time. But that's why you're supposed to turn the engine over twice and then check your marks.
| Timing Belt Replacement | MarkB | Tech & Performance Forum | 38 | 30 Apr 2010 07:38 am |
| Running Rough...New timing belt, water pum and spark plugs | lanies_ptcruiser02 | Tech & Performance Forum | 15 | 05 Sep 2008 09:59 pm |
| loose timing belt and gears not moving - urgently need help pls. | lanies_ptcruiser02 | Tech & Performance Forum | 12 | 12 Aug 2008 05:36 am |
| Another timing belt question thread :) ??? | Ctown | General PT Cruiser Discussions | 4 | 24 May 2005 08:50 am |
