Engine light P2097 error code help
Old 19 May 2009, 06:56 pm
Default Engine light P2097 error code help
Hey guys,
I got the check engine light while cruising down the interstate the other day. I checked for the code using the key/odometer and it comes up P2097. I can't seem to find much info on this code and was wondering if anyone had any experience or info. It's a '05 base PT w/ 44k miles. Car seems to be operating normal.
Thanks.
Old 19 May 2009, 07:50 pm
Default Re: Engine light P2097 error code help
From PT Do-It-Yourself.net
You'll notice that there are a number of possible causes for this fault. If you have some experience with automotive repair you may be able to check a few of these possibilities out on your own, however keep in mind that the diagnostics are written for trained auto technicians who also posses the necessary test equipment.
Given that this is an intermittent issue it may be somewhat difficult to accurately diagnose unless you can duplicate the issue. The dealer will experience the same difficultly troubleshooting the issue unless they can reproduce the problem at will. Regrettably, you may have to wait for the component in question to fail before you can obtain an accurate diagnosis.
P2097-Down Stream Fuel System 1/2 Rich
Possible Causes
Good Trip Equal to Zero
Exhaust Leak
Engine Mechanical Problem
O2 Sensor
O2 Signal Circuit
O2 Return Circuit
Fuel Contamination
There's also a TSB (Technical Service Bulletin out for it.....
Date: 09/03/2004
Component Name: 110000 ELECTRICAL SYSTEM
NHTSA #: 1803604
SUMMARY: MALFUNCTION INDICATOR LAMP DIAGNOSTIC TROUBLE CODE P2097 P2099. *TT
2000 PT. 100,000 miles, Original Owner
Old 20 May 2009, 12:30 pm
Many Thanks for the info...
Check engine light just came on! lajag24t Tech & Performance Forum 22 13 Aug 2009 05:22 pm
"Check Engine" idiot light on AGAIN tezz General Turbo Discussions 13 21 Mar 2009 02:53 pm
Engine Light Stays On - OBD vinzchlortho Tech & Performance Forum 6 30 Nov 2008 07:01 pm
Check engine light, skipping ab1 Tech & Performance Forum 2 02 Aug 2008 11:13 pm
06 turbo check engine light 06SilverTurbo Tech & Performance Forum 23 21 May 2008 02:20 pm
  Debt Consolidation | Plane Tickets | Jobs search | Online Advertising | Electronics
