Air Conditioner lines freeze - why ??
  #21 (permalink)
Old 29 May 2009, 07:47 am
Default Re: Air Conditioner lines freeze - why ??
quintas,
That's perfect. Great write-up. So much for Chilton and Haynes Manuals that both have the same picture I posted at the beginning of this thread showing the HIGH Pressure switch on the accumulator. That's the one that caused my system to freeze up and the one they replaced (twice because of the O ring).
  #22 (permalink)
Old 29 May 2009, 04:14 pm
TexasPriest's Avatar
Originally Posted by quintas View Post
THE LOW PRESSURE SWITCH ON THE ACCUMULATOR HAS IT'S OWN SHRADER VALVE AND CAN BE REPLACED WITHOUT DISCHARGING THE SYSTEM. SCREW ON, SCREW OFF.
CAUTION!!
THE HIGH PRESSURE SWITCH IS UNDER PRESSURE AND HAS NO SHRADER VALVE. THE SYSTEM NEEDS TO BE DISCHARGED BEFORE YOU CAN REMOVE IT! (NOT RECOMMENDED FOR NOVICE'S)
Thank you for the info!!
I just talked to the service guy and he confirms it's the Low Pressure switch. They are charging me $65 for the switch and 1.5 hours labor at $160 an hour! So unless you can think of a reason why I shouldn't just change the switch myself, please let me know
Based on your post, I should be able to disconnect the switch, unscrew, screw in new switch and reconnect wires. Any further details, if needed, would be greatly appreciated.
Texas Priest
2006 Electric Blue PT Cruiser Touring Edition
43K Miles, 4 Cylinders B 2.4L SFI DOHC
So...How's the whole "hopey-changey" thing working out for ya?
  #23 (permalink)
Old 29 May 2009, 04:23 pm
quintas's Avatar
As long as the switch is located on the accumulator you should be able to screw it off and screw on the new one. If you're going to re-use the exsisting oring on the threaded fitting, make sure it's not damaged. If it is,
replace it. Then reconnect the electrical plug, and your in busines!.
  #24 (permalink)
Old 29 May 2009, 04:29 pm
Good Deal! Thanks Again.
I almost don't want to mess with this because ever since they diagnosed the problem, the AC has been working like it should. But i guess once a switch goes bad it just a matter of time before it acts up again.
Texas Priest
  #25 (permalink)
Old 29 May 2009, 06:27 pm
OK, one more question. Is this the part?
AutoZone.com | Vehicle Selection | Year
Texas Priest
  #26 (permalink)
Old 29 May 2009, 07:47 pm
TP - That looks to be it.
I actually went and got the earlier posted switch - HP switch which was at O'Reilly. It was obviously the wrong switch, installed with a snap ring rather than threaded into the top of the Accumulator. This IS in fact the HP switch installed on the back of the compressor.
Quintas, great post, clears things up a bunch through all these threads. I wondered how the HP switch could cause the lines to freeze without in fact causing the system to rupture.
TP - I would say that IS in fact also what the dealer wants to charge you to change, although I can't imagine why they'd charge that labor cost. Seems to be a faily easil accessible area and if the switch does in fact just screw on and off, no need for much more than 30 minutes. I wonder if they are charging to vacuum and recharge the system after they're done. The parts price does make sense as well. Autozone charging $30 would translate to a Chrysler direct part eing in excess of $55.
O'Reilly parts could not find the switch in their system. They told mne I'd have to go to Chrysler for it.
Thanks all.
'06 PT Touring
  #27 (permalink)
Old 30 May 2009, 02:28 pm
160 an hour? Holy.... Wow! Our dealership only charges $100 an hour. Where are you going?
  #28 (permalink)
Old 30 May 2009, 02:52 pm
Dallas F**king Dodge
Texas Priest
  #29 (permalink)
Old 30 May 2009, 11:45 pm
outfit's Avatar
Send a message via Yahoo to outfit Send a message via Skype™ to outfit
man alot of info here, to bad this was not up when it went out on my wife. Of coarse it happened when I was layed up in the hospital with a lower back fusion... So just to confirm..... this has no pressure , it can be unscrewed , replacing the o rings and then screwed in. Without having to take it in to a dealership or auto mechanic and have them use a sand paper "glove" on you........ Just want to make sure because my wife is going to get her mechanic on......
<---- Just installed.
2006 PT Cruiser Touring Non-Turbo
3 -Hyper White Thin Flexible 5mm LED Dome Lights from Oznium Damn they make a dif in the inside ,let me tell you the best led lights you can buy
1 -Hyper White 921 Superstar Bulbs from Autolumination
1 -Hyper White T10 Wedge 194 (Lic Pllate) Super White LED from Autolumination
Pioneer Head unit W/ HD & Satellite radio
2 - 7inch DVD/Headrests Monitors... dvd players built in the headrests
HID Lights 8000k 9006 for lows from xhidoutlet....
HID Slim 55w 6000K for high's from HIDGEEK.
  #30 (permalink)
Old 31 May 2009, 02:59 pm
Was it 160 an hour or 160 for the entire repair? $160 an hour is EXTREMELY excessive.
VAC lines rice_killing_GT Turbo Performance 11 05 Feb 2012 02:03 pm
Air Conditioner Impacting Engine ronnick9 General PT Cruiser Discussions 5 21 May 2009 10:07 pm
AC Lines freezing up... Is there a quick fix? outfit Tech & Performance Forum 14 20 Apr 2009 05:57 pm
Heat / AC distribution freeze up calflan Tech & Performance Forum 2 18 Feb 2009 08:04 pm
Electronic Portable Air Conditioner h.fork Classifieds: For Sale/Trade 1 29 Sep 2006 09:08 am
