Alternator Upgrade?
Old 28 May 2009, 01:19 pm
Default Alternator Upgrade?
I read on other sites that pt cruisers use generators instead of alternators. Would I be able to just swap out the oem for a high output alternator, or do i need to change some wiring from the generator?
Old 28 May 2009, 01:46 pm
Default Re: Alternator Upgrade?
The PT uses an Alternator with a built-in generator. You should be able to just replace the one you have with a higher output unit as I was given the choice of a higher output when I replaced mine but stayed with the OEM specs, but I'd do some more checking here or at your local auto store.
Old 31 May 2009, 11:26 pm
has anyone done an alternator upgrade? Or have an alternator upgrade guide?
