Transmission Fluid
Old 31 May 2009, 01:54 pm
Default Transmission Fluid
How may quarts of fluid would my 02 use in a change and what type should I use?
Old 31 May 2009, 02:17 pm
Default Re: Transmission Fluid
You will need to add between 4-5 quarts,depending on how much old fluid you are able to coax out.Your car uses ATF+4.
Clark
Old 31 May 2009, 07:48 pm
Automatic?
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 31 May 2009, 08:16 pm
Yes. I am going to take it in for a change and I want to make sure the mechanic uses the right stuff. I usually do most of my own work but time is tight.
Old 31 May 2009, 09:04 pm
Should alternate every 30k with a drain and fill and a full service tranny flush.
Manual Transmission Fluid Change matt87951 Tech & Performance Forum 22 11 Apr 2011 03:42 pm
Transmission fluid leak tryanmax Tech & Performance Forum 16 22 Jun 2010 03:13 pm
Transmission Fluid for '02 2.4L Limited Edition... missingwhatsnear Tech & Performance Forum 1 19 Feb 2009 09:12 pm
GT Auto Transmission fluid capacity? silky General Turbo Discussions 4 19 Mar 2006 10:54 pm
I think my tranny's about to go! TaylorMade Tech & Performance Forum 25 01 Apr 2005 12:46 pm
