check engine on, automatic only third gear
Old 01 Jun 2009, 08:15 am
Default check engine on, automatic only third gear
hello,
I have a neighbor with a 2001 Pt cruiser that has a mouse problem He told me that he found a mouse in the air filter compartment. He also showed me some wires and hoses with mouse signs.
Now the car has the check engine light on, and the automatic transmission only shift to the third gear. Is this some kind of limp home mode ?
I will go later today with my ELM 327 to see if it can read the error. I also read on the forum that I can see the error code on the display.
Any ideas ?
Old 01 Jun 2009, 09:37 am
Default Re: check engine on, automatic only third gear
the error code is
P0700 Transmission Control System Malfunction
i reseted it with the OBD interface, and the after 200 meters of driving the chech engine light came on again. Any ideas, please
Old 01 Jun 2009, 02:56 pm
so, after I reset the first error, and took the car for a ride, after it tried to change from the first to second gear the check engine light came on again, but now the error code is:
P0605 Control Module Programming Read Only Memory (ROM)
I checked all the wires for damage and they seem OK, I'm lost...
Old 01 Jun 2009, 09:31 pm
You are going to need a new Transmission Control module. You have an internal failure in the TCM. The transmission defaults to 3rd gear to allow you to drive the vehicle to get it worked on.
Old 02 Jun 2009, 02:15 am
Thanks for your reply. Normally that's what I also figured, TCM error, TCM replace. But my neighbor is saying that the error appeared at the same time, as when he discovered the mouse in the engine compartment.
I guess today I will check all the wires (again), and if I don't find anything damaged, I will look for a module on eBay.
"Check Engine" idiot light on AGAIN tezz General Turbo Discussions 15 23 Jul 2010 06:09 am
Check engine light just came on! lajag24t Tech & Performance Forum 22 13 Aug 2009 05:22 pm
Check engine light, skipping ab1 Tech & Performance Forum 2 02 Aug 2008 11:13 pm
06 turbo check engine light 06SilverTurbo Tech & Performance Forum 23 21 May 2008 02:20 pm
Check engine oil light question AaronR General PT Cruiser Discussions 5 28 Aug 2004 03:18 am
