Possible Ignition Problem
Old 01 Jun 2009, 10:29 am
Default Possible Ignition Problem
Hi my PTC will not turn over with the key in the barrel. I have taken off the plastic surround around the steering wheel and removed the indicator stalks. This has enabled my to remove the ignition switch. i can see the bar that turns when the key is turned. I can turn the car over with a screwdriver no problem, it seems when i use the key it will not turn enough to start the car, do you think i need a new ignition barrel? are they prone to wearing out? as i said its not a electrical fault because the car starts when i manual turn the ignition swtich
Old 01 Jun 2009, 09:35 pm
Default Re: Possible Ignition Problem
You will need to replace the ignition lock cylinder.
Ignition coil problem...maybe? pcm2a Tech & Performance Forum 19 06 Sep 2011 09:04 pm
Ignition coil problem? Donna General PT Cruiser Discussions 9 20 Aug 2010 08:39 am
Horn/Radio Problem Madturtle Tech & Performance Forum 4 11 Apr 2009 10:54 am
07 Touring - Intermittent Starting Problem DravenGSX Tech & Performance Forum 8 19 Mar 2009 05:58 am
$50 (paypal) to whoever can solve my A/C problem intend Tech & Performance Forum 5 03 May 2008 08:08 pm
