Surge?
Old 01 Jun 2009, 09:01 pm
Default Surge?
When I start my 02 the rpm's jump up to about 1500 for a second. I never noticed this. Is it normal or dose it have something to do with my idle problem?
Old 02 Jun 2009, 10:28 am
Default Re: Surge?
Shouldn't jump. Could have a dirty/malfunctioning IAC or a loose/torn/unconnected vacuum hose.
Old 02 Jun 2009, 10:35 am
Default Re: Surge?
Cant wait for the weekend to look into all of this. What about the manifold gaskets? Do they have a rep for going south?
Old 02 Jun 2009, 10:47 am
Default Re: Surge?
No, they are rubber/silicone and be re-used over a couple times, but you can try re-tightening them. It only takes 8 ft lbs for each nut (5) so don't over-do it, they break pretty easily. If loose, you'd have a vacuum leak which would cause problems, but they don't come loose by themselves. Have yo had any work done lately?
Old 02 Jun 2009, 11:29 am
Default Re: Surge?
Last time I worked on it was to put in new plugs and wires to try to solve the idle problem. So the problem was there. I would like to know how to test the IAC if any one knows how. Just one of the things I would like to check. Dont want to just clean and hope and at 80 bucks I dont want to replace it if its good.
Old 02 Jun 2009, 11:35 am
Default Re: Surge?
I haven't done it myself, but it's pretty easy to take off and I'm told by someone who did it that you can see how it works and can see if there's any trapped dirt/debris inside and clean it out. One owner found it was clogged and wasn't working right and cleaning it solved his idle problem.
Engine Surge at highway speeds UncLarryWasRight Tech & Performance Forum 9 18 Jul 2008 12:54 am
idle miss and boost surge mtnbktrek General Turbo Discussions 7 02 Feb 2007 04:08 pm
Unknown RPM surge problem (manual) Ctown Tech & Performance Forum 4 26 Dec 2004 08:48 pm
Compressor Surge bigtommy83 Stage Turbo Kits 11 22 Dec 2004 08:23 pm
power surge skeeter1620 Turbo Performance 6 30 Dec 2003 03:08 pm
