The parking brakes can indeed be adjusted using the tech manual procedure as posted but if you are used to doing brake jobs; there is an easier way. I did one side using the manual procedure and had great difficulty doing so. I then removed the wheel and the caliper. From there, I could clearly see the star adjuster and reach it easily. All you have to do is adjust it out some and test fit the disk. If you can't get it on or it drags excessively just back off some. Adjust, fit and test until it barely doesn't drag. It takes almost as long to tell about it as it does to do it. Additionally, you can inspect the drum and shoes and lube the bolts that hold the calipers in place.
Some pictures might help. The first is an overall picture of the shoes on the rear disk brake. The second is the drum portion of the disk with a screw driver pointing to where those cute little shoes have rubbed the drum portion of the disk and the third is the star that adjusts the shoes with the shoe to the left and the hub to the right,. It is meant to be reached through the rubber plugged hole in the backing plate. A look at these emergency/park brakes tells me that they should only be used for important things like bootleg turns on the ice, dire emergencies involving loss of all brakes and, of course, parking. Not the frivolous things like scrubbing off speed for LEO's without lighting the brake lights..... Last edited by Mal; 20 Aug 2009 at 05:36 pm. |
Let me get this straight, this above is for the read disc brakes, and not drums, correct? Edit: Nope for rear drums
2003 PT Cruiser GT, turbo, Inferno Red Pearl, autostick, 84K, MSD 8.5m wires, NGK iridiums Last edited by dsmturbo; 20 Aug 2009 at 09:30 pm. Reason: oopps |
The confusion comes from the fact that the parking brakes consist of a drum and shoes inside the rear disk. The "hat", if you will of the disk is the drum for the parking brake. Inside that hat are shoes but the main, hydraulically operated brake, is a disk, caliper and pad. The parking brake is cabley operated and a pair of shoes inside the raised portion of the disk. I know I'm doing a lousy job of explaining it or it would be understood. I'll try to learn how to post pictures; this forum software looks so much like others I've used I thought it would work. The pictures open fine for me even on another computer....dsmturbo; if you're pullin my leg, I'm gonna reach through your computer and bop you on the nose, a la 3 stooges.... Last edited by Mal; 20 Aug 2009 at 09:56 pm. |
Listen up guys and gals, he's been trying to tell you - the rear discs have a shoe INSIDE the rotor, for the parking brakes!
If you will please look at the attached, this is right out of the parts catalog for the 2005 PT GT, it's the rear brake assembly, including the shoes for the parking brake. Anybody else? I got parts catalogs for almost every year, plus the service manuals. To knab this page from the parts manual click HERE! The page was too large to upload on the forums. |
1973 Barracuda 340/auto Modifications: Too many. 2002 PT Cruiser N/A 2.4L/5-speed Modifications: Boogers, Maddog 80% STS, Auto throttle body, Airbox modifications, Eibach Pro springs, Energy Suspension control arm bushings & motor mount inserts, disabled balance shafts. 1989 Caprice Wagon 307/auto Modifications: Lowered 2" front and rear, flat black paint, emblems and trim removed and filled, pinstriping, big 'n little tires. |
Hey CN or MM, could you look in the manual and see if there is a specification for how many clicks you get to a tight parking brake lever. I have several manuals and those with lever type parking brakes list a specified number of clicks.
| Drum brake replacement Parking brake cable | Dorkygrin | General PT Cruiser Discussions | 2 | 28 Mar 2009 07:53 pm |
| parking brake light going on??? | yobiebs | Tech & Performance Forum | 8 | 01 Nov 2007 09:25 am |
| Parking Brake Light upon Acceleration | JohnM | Tech & Performance Forum | 5 | 27 Jan 2006 09:07 am |
| Parking Brake Light comes on when shifting | patbluecruiser | Tech & Performance Forum | 6 | 17 Dec 2004 07:33 pm |
| Parking brake light coming on | CHROMEDCRUISER | Tech & Performance Forum | 8 | 06 Dec 2004 10:11 pm |
