Need to tighten the parking brake any repair insight?
66CUDA |
I would like to know too....my parking brake has to be yanked up as far as it possibly can to keep the car from rolling....and than its a bugger to release it...especially for the wife
Mr. Mikes welting, chrome valve stems and caps, leather ebrake boot,chrome change holder cover,black/red leather steering wheel cover, chrome antenna bezel and chrome 12:" antenna,rear quarter window decals, winter car cover for winter storage, special made DREAM CREWZER dash plaque.upper windshield eyebrow tint , gts headlight protectors, carbon fibre taillight covers,car cover,K&N drop in filter, AMX intake pipe, shiny metal steering wheel spoke covers:Mopar door sills, rear chrome licence insert.street series badge,billett grill,engine start button, red brake calipers,painted engine manifold,chrome vent knobs,chrome/carbon fibre shift knob![]() ![]()
Anyone know? Do I have to remove the console and rachet a nut attached to the cable from the lever????
66CUDA |
From PT Do-It-Yourself.net:
The parking brake is self -adjusting and only applies to the rear brakes. The parking brake lever automatic-adjusting feature continuously applies minimal tension to the parking brake cables to keep them in adjustment at all times. Therefore, the parking brake cable system does not require adjustment. Proper parking brake system adjustment is obtained by proper drum brake or drum-in-hat brake shoe adjustment. This section of the service manual is extensive and contains numerous illustrations and instructions, therefore we're not able to provide it in its entirety. We recommend that you borrow or purchase a service manual prior to attempting any adjustment to the brake system.
I appreciate the insight and concern but I have done this repair before on various vehicles I have owned. It usually is a simple 20 minute repair in which a nut is tightened on a cable under the car or under the center console. Hopefully, someone on this sight has made this quick fix.
66CUDA |
Just adjusted the park brake on a Lexus which has the same "non adjustable cable rear drum in the disk", system. It was quite simple. Remove a rubber plug, put the resulting hole a 6 oclock, use a screwdriver to adjust a star screw inside until the drum/disk won't move and back off just a bit. It adjusts just like the old drum brakes did. The slot could just as easily be in the back but I can't imagine it being much different but with DC, who knows....
I'm sorry, I wasn't very clear. I was referring to rear disks. The parking brake consists of a drum and shoes contained within the rear disk. In effect the rear brake is disk and the parking brake is a drum. Disks are by their nature self adjusting, drums are not. I have only done one brake job on the PT and didn't notice the adjusting hole so I suspect it is on the rear, on the backing plate; not on the disk itself like the Lexus.... I believe the cables are self adjusting.
This is from my 2002 FSM regarding adjusting the parking brake shoes on disc brake cars.
1) Verify the parking brake lever is in the released position. 2) Raise the vehicle. 3) Remove the rubber plug from the adjusting hole in the disc brake caliper adapter. 4) Adjust the parking brake cables. Use the first bullet point for the adjustment of the left side parking brake shoes. Use the second bullet point for the adjustment of the right side parking brake shoes.
6) Lower the vehicle until the rear tires are just clearing the floor. 7) Reach inside the vehicle and fully apply and release the park brakes two times after adjusting the parking brake shoes. 8) With the parking brake lever in the fully applied position, attempt to hand rotate each rear tire and wheel assembly to ensure that the parking brake shoes are working. 9) With the parking brake lever in the released position, hand rotate each rear tire and wheel assembly to ensure that the parking brake shoes are not dragging. There are no pictures in the manual for this so you'll have to go by what you see under the car when doing it.
1973 Barracuda 340/auto Modifications: Too many. 2002 PT Cruiser N/A 2.4L/5-speed Modifications: Boogers, Maddog 80% STS, Auto throttle body, Airbox modifications, Eibach Pro springs, Energy Suspension control arm bushings & motor mount inserts, disabled balance shafts. 1989 Caprice Wagon 307/auto Modifications: Lowered 2" front and rear, flat black paint, emblems and trim removed and filled, pinstriping, big 'n little tires. |
Thanks Mopar Man. That's exactly how brakes were adjusted in the old days. Just when you think drum brakes are a thing of the past; like wide ties, they come back. You may be able to see the star adjuster as you look through the hole making the use of a relatively thin screwdriver possible. Otherwise use as wide a device as you can get through the slot. There is a drum brake tool available for this task. It looks like a bent wide slotted screwdriver.
If the adjuster stops moving and the disk is not locked you are adjusting it the wrong way. The two pulls on the handle, no doubt are the self adjusting feature of the cables. I just noticed one of your cars is an '89 Caprice Wagon. The C4C I used for the Elantra was an '88 Caprice Wagon also with the Y (olds) motor ..... hated to see it go but the kids are all out of college. I also had a '64 1/2 Barracuda 273 4 spd. It and a '62 Valient 3 spd were fairly good Mopars. Last edited by Mal; 18 Aug 2009 at 05:34 pm. |
| Drum brake replacement Parking brake cable | Dorkygrin | General PT Cruiser Discussions | 2 | 28 Mar 2009 07:53 pm |
| parking brake light going on??? | yobiebs | Tech & Performance Forum | 8 | 01 Nov 2007 09:25 am |
| Parking Brake Light upon Acceleration | JohnM | Tech & Performance Forum | 5 | 27 Jan 2006 09:07 am |
| Parking Brake Light comes on when shifting | patbluecruiser | Tech & Performance Forum | 6 | 17 Dec 2004 07:33 pm |
| Parking brake light coming on | CHROMEDCRUISER | Tech & Performance Forum | 8 | 06 Dec 2004 10:11 pm |
