Always at the wrong time....
Old 03 Jun 2009, 09:36 am
Default Always at the wrong time....
Got in my Cruiser this morning to go to work just like I have for the last year and a half. Drive about two miles, just getting onto the Interstate on ramp and I hear a bell. Look down at my dash and see the battery light is on. I have to drive about 4 miles to get off the Interstate and turn around. Got home, turned the key off and then restarted the engine. No immediate battery light. So now I don't know if it was just a glitch or if I have a problem.
Last night on the way home we had some terrible storms, almost couldn't see ten feet in front of yourself at times. Also a lot of, what I thought was heavy, hard hitting hail, although when I got home I could not find any damage, no dents, nothing. Maybe I kicked something up into the engine compartment that caught something and dirtied a contact.
I didn't have time to look into it further or I would have been late to work (wasn't). So I'll have to check into it this evening, hopefully no more rain or storms for a few days.
2001 LE, Shale Green, Aftermarket Wheels, Shorty Antenna, AirRaid Cold Air Intake, Whelen Talons (amber/white) in front windshield, Whelen Talons (amber) in rear side windows, Tomar RECT25's (amber) and Whelen Slimlighter(amber) in back window. Kenwood TK-880H 45 Watt Mobile Radio, Antenex 3db antenna w/ NMO mount.
http://smg.photobucket.com/albums/v7...0PT%20Cruiser/
Old 03 Jun 2009, 03:12 pm
Default Re: Always at the wrong time....
I'd take the air filter off anyway and clean both terminals and look around. Can't hurt.
Old 03 Jun 2009, 03:45 pm
I'm going to look at it this evening. Funny thing was when I restarted it, the battery light went out. I'm wondering if the belt isn't tight enough. I know I've been having problems with the air conditioner clutch. So I wonder if it didn't tighten up and causing the belt not to turn or not to turn all the time. If that is the case, I'll just have to have a belt for w/o air conditioning installed as I don't have the money right now to buy or even repair a compressor. Actually right now I'm hoping it is something that simple.
Old 03 Jun 2009, 04:39 pm
I'm getting P1682, which according to the codes listed above, it means:
P1682 Driver 5 Line 2
which means nothing to me. Can someone decipher? Is this something I can reset by undoing the battery cable for a few minutes?
Old 03 Jun 2009, 04:54 pm
After I asked the question about the error code I did a further Google search and found something about charging voltage being low. Cause could be a loose, or worn out belt. So I went back out to take one more look. Starting the vehicle up, after about 30 seconds, the battery light comes on. Rev the engine up to higher rpm and after about 30 more seconds the light goes out until you go back to idle, then after 30 seconds it is back on.
I'll take it to my local Car-X tomorrow morning and see about either tightening up the old belt or putting on a new one. Hopefully that will fix the problem.
Old 03 Jun 2009, 05:07 pm
The main serpentine belt has an automatic tensioner so no adjustment can be made but the alternator does have it's own belt and the alternator itself can be adjusted to tighten up or loosen the belt. Depending on your mileage, maybe both belts need to be replaced. We try to tell everyone that goes in for the timing belt to change the water pump and drive belts while the work is being done.
Old 03 Jun 2009, 06:14 pm
I have no where near the funds to even think about changing the timing belt. Nor am I getting any indication that it needs changing. Also at 132,000 miles, I suspect it has been changed once.
I assume the alternator belt also powers the air conditioner compressor, correct? That's the belt I think needs replaced, or at least tighten.
Old 03 Jun 2009, 06:21 pm
I could be wrong but what I'm seeing in the manual, the alternator belt is separate. Everything else including the compressor runs off the serpentine belt.
Old 03 Jun 2009, 07:48 pm
Either of us could be. I looked this morning on Auto Zones web site. They showed a belt for both with and w/o air conditioning. That's where I got my info. I'll find out tomorrow morning.
Old 04 Jun 2009, 08:09 am
It wouldn't even turn over fast enough to start this morning. I should have jumped it this morning but didn't want to take the chance of not getting it done and then being late for work. So I'm leaving here at noon. Hopefully I can get it into a shop and checked out. If it is more than just the belt, she is just going to have to set for a few weeks until I get the funds to have it fixed.
A/C and idle problem (hopefully the last time) sflamedic Tech & Performance Forum 13 27 Jul 2008 01:34 pm
Recommended warm-up time dbraveman General PT Cruiser Discussions 9 12 Feb 2004 09:38 am
Okay, Its about done....MG time. cruisergeo Non-PT Discussions 1 05 Sep 2003 11:32 am
Time Test satellite66 Testing 3 14 Aug 2003 08:33 pm
Won't start first time Mike Radowski Turbo Performance 1 14 May 2003 02:34 pm
