MSD Coil Type For "B" engine
Old 06 Jun 2009, 09:31 am
Default MSD Coil Type For "B" engine
All:
I have an 05 Limited non turbo. I m looking to upgrade the ignition coil. I searched the MSD website and there are two listed. They state that the terminals on the coil can be either round or flat. I cannot check this on the car because of the intake. Does anyone know? Is one listed for turbo and the other for non turbo? I just cannot leave well enough alone so I am doing some bolt on engine work. I am sure the stock coil will be fine with my Magnecor wires but it won't look as good.....Thanks ahead of time. Next: intake.
PTZee
Old 06 Jun 2009, 01:17 pm
Default Re: MSD Coil Type For "B" engine
Originally Posted by PTZee View Post
All:
PTZee
The stock coil is more than adequate. Aftermarket coils for the PT are a waste of money.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 06 Jun 2009, 01:27 pm
PTZee
PTZee,
As Mean Green already said, the stock coil is quite adequate for even a modified non-turbo PT. As far as not looking good with your wires, both the coil and wires aren't seen because of the upper intake and there's not a whole lot you can do to the intake to change that.
If you HAVE to spend your money, the terminals are round on the stock coil.
Ignition coil problem...maybe? pcm2a Tech & Performance Forum 19 06 Sep 2011 09:04 pm
Engine swap / replacement compatibility Brent72 Tech & Performance Forum 2 28 Jan 2009 07:23 pm
Review: $2200 for a NA replacement engine PT Ctown General PT Cruiser Discussions 8 24 Jul 2006 01:08 pm
