Lower control Arm Bushings BOLT
Old 09 Jun 2009, 04:53 pm
Default Lower control Arm Bushings BOLT
The bolt that holds the rear, lower control arm bushing on my PT has seizes. I've sprayed the heck out of of it with a penetrating oil ad whacked it with a hammer a few times. Also tried the air gun on it but it won't budge.
Is there a way to get at the top of it to pour some penetrant on top?
Any other suggestions?
I'm leery of using a breaker bar in case it snaps the bolt.
2001 Taupe Limited 5 speed manual. Bought new and the first one to be sold by the dealer.
Old 09 Jun 2009, 07:45 pm
Decsr's Avatar
Default Re: Lower control Arm Bushings BOLT
I had to use my version of a breaker bar on mine to get that bolt loose. I use an 18-inch section of pipe on the end of my long ratchet to give me the leverage to break things loose.
This PT Convertible use to be my BABY it was a 2005 Base 5 speed, Black on black on black, Red rims with full moons hubcaps, Amber fog lights, 6 disc indash CD, Polk speakers, Suicide knob, Black 15" spring ant., Gauges in console, APC air filter system, Complete bullet/turbo exhaust system, Hurst Shifter. May its new owner enjoy it as much as we did. We do still have a 2007 Limiter PT in Cool Vanilla with no mods and two HHRs now.
Old 10 Jun 2009, 08:47 am
Duster's Avatar
Heat it
Old 10 Jun 2009, 02:00 pm
oldcoach's Avatar
On the PT Crew you will find just what you need to do
PTCrew.com - Learn it or Burn it.
02' Black Woodie Limited Edition Drop in K&N Air Filter w/air box mod. 06 tail lights, Limo tint all around, orange LED interior, Mopar 8 inch sub, Stull side pipes. Silver stars upfront, a little chrome
Check Engine Light came on - code 1188? coolvirus General Turbo Discussions 38 25 May 2011 09:01 am
cost for replacing lower control arm bushings tm05cruiser General PT Cruiser Discussions 8 10 Jul 2010 07:50 pm
obd-II codes Punch General Turbo Discussions 13 06 Jul 2009 06:54 pm
Lower Control Arm Bushings at 25K miles???? NewPTCruiserInPA Wheels, Tires, Suspension 23 30 Nov 2008 07:21 pm
problems with lower control arm bushings ValAir Turbo Wheels/Suspension/Handling 34 31 May 2007 03:44 pm
