Code P0171
Old 12 Jun 2009, 05:41 pm
leftoverture's Avatar
Default Code P0171
Got a code P0171 on the cruiser (year 2001). I know there are lots of things it can be. Just wondering if any of you have had it and what it was in your case?
Thanks.
2001 PT Cruiser Limited Edition
Old 12 Jun 2009, 06:17 pm
Default Re: Code P0171
From PT Do-It-Yourself.net:
P0171 - 1/1 Fuel System Lean - A lean air/fuel mixture has been indicated by an abnormally rich correction factor.
There are a number of possible causes including:
Restricted Fuel Supply Line
Fuel Pump Inlet Strainer Plugged
Fuel Pump Module
O2 Sensor
O2 Signal Circuit
O2 Return Circuit
O2 Sensor Heater Operation
Throttle Position Sensor Sweep
MAP Sensor Operation
ECT Sensor Operation
Engine Mechanical Problem
Fuel Contamination/Exhaust Leak
The majority of tests performed to rule out each component require the use of a DRB III scan tool and or special equipment which most owners do not have, therefore your ability to DIY will be limited. However the diagnostic that I provided will give you some idea on which areas to focus on.
As far as others on the forum having that same code:
P0171 Error code
Oxygen Sensor
OBD 2 code reader bompa45 Tech & Performance Forum 3 03 Jun 2009 10:27 pm
Error code trouble P0132, 1686, 1687, 1681 SolidusGorto General PT Cruiser Discussions 0 19 Jun 2008 07:59 am
Dark Plum paint code ChaosTheory The Detail Shop 3 18 Mar 2008 11:03 pm
P0171 Error code RIvey Tech & Performance Forum 3 02 May 2007 10:24 am
Need diag. code info RIvey Tech & Performance Forum 1 01 Oct 2005 12:05 pm
