Pt shut off while driving!
Old 16 Jun 2009, 05:42 pm
Default Pt shut off while driving!
I have a 2003 Pt Cruiser non turbo. while driving my car abruptly shut off and the check engine and oil light came on. At this point the car won't start and i'm getting an error code p0016. I have also had problems with my pt overheating and had the thermostat and radiator cap replaced. since then i haven't had it overheat, but even before i replaced those parts it would only overheat periodically. are these problems related? if so, how do i fix this, start with the cheapest solution.
Old 16 Jun 2009, 06:12 pm
Default Re: Pt shut off while driving!
Don't think the overheating has anything to do with it but that's just a guess.
Have you had any work done recently, like a timing belt? The code could be that your belt has snapped. If it is, sorry, there's no easy and cheap fix. It's about 5-7 hours of labor plus you should also change the water pump, tensioner, drive belt and alternator belt as they are all in the same area and all probably have the same mileage. We're talking here somewhere in the range of $800 to $1200 depending who you get to fix it and the price of the parts.
The "car abruptly shut off and the check engine and oil light came on" is a sure sign of a major failure like the timing belt. The really bad news (as if just the belt isn't enough) is that there could be internal damage to the engine. Thankfully, I've only heard of 1 other person that needed internal work done after the belt broke while driving.
Old 16 Jun 2009, 06:30 pm
the only thing i had replaced was the thermostat and radiator cap. ran fine until yesterday. is there anyway i can telll if its the timing belt myself, or do i have to take it in to a shop?
Old 16 Jun 2009, 06:38 pm
Some say you can take off the top cover which is held on by two bolts or see part of the belt from underneath but I've never tried either way.
Old 16 Jun 2009, 06:59 pm
so there are no definite symptoms for a broken timing belt? could it just be the cam/crank sensors as the error code suggests? Btw thanks for all your advice,it's much appreciated.
Old 16 Jun 2009, 07:00 pm
Travis2k7's Avatar
P0016 code = crankshaft/camshaft timing misalignment
How many miles are on your PT?
The word around here is 90-100k is the life of the timing belt.
2006 Limited, Auto, 100k miles
Old 16 Jun 2009, 07:03 pm
only 80k, i don't do much driving. just work to home.
Old 16 Jun 2009, 07:10 pm
Travis2k7's Avatar
A quick google search just yielded the same results... could be the sensors, could be the timing belt... (not necessarily broke, but it could be skipping)
Good luck.
Old 16 Jun 2009, 07:12 pm
Good luck.
thanks for your help.
Old 16 Jun 2009, 07:17 pm
Travis2k7's Avatar
No problem... I'd have it looked at ASAP, preferably by a trusted mechanic over a stealership.
Keep us posted.
Popping sound while driving arkansascarnut General PT Cruiser Discussions 7 18 Jul 2014 09:16 pm
32.9 miles per gallon driving my GT!!! Gary04GT Turbo Performance 56 14 Jul 2013 02:18 am
Replaced thermostat, but engine temp says cold while driving... missingwhatsnear Tech & Performance Forum 5 11 Feb 2009 08:39 pm
Door stuck shut, seat belt not working audbene General PT Cruiser Discussions 2 02 Feb 2009 11:23 pm
