pt blowing fuse to shut off engine ?
Old 17 Jun 2009, 06:21 pm
Default pt blowing fuse to shut off engine ?
Hi I am a new user here , i Have a 2001 pt LE and once and a while i am blowing the 20a fuse that shuts off the engine , but soon as i change the fuse its good for awhile again like 2 -3 days ? has anybody eles had this problem or if they know what it is ? Help !
Old 17 Jun 2009, 08:07 pm
Default Re: pt blowing fuse to shut off engine ?
Welcome.
Which fuse? Under hood? What is it labeled as? Look for what else is on that circuit.
Haven't read of anything like your problem.
Old 23 Jun 2009, 10:32 pm
HI sorry never got back to you right away , thanks for your reply , its never blew again for some reason ? so now i cant find the problem , ? I drove for about an hour in it , then went for a long drive , again no problem , but i checked the engine and only found a vacume line off ? dont know if that made somthing over heat , but everything is good for now willl keep in touch if problem arrises again once again thank you for your help , hope i can use you in the future ! Murray
Ignition Off Draw (IOD) Fuse Effects and Replacement Hints ObiMatt87 Tech & Performance Forum 25 30 Apr 2017 08:33 pm
fog lamp fuse blowing smilanatu Tech & Performance Forum 13 19 Jul 2009 11:07 am
HEATED SEATS (FUSE KEEPS BLOWING) BIGZ General PT Cruiser Discussions 9 16 Feb 2009 10:39 pm
The noise engine makes when you shut off? stirfry Tech & Performance Forum 7 26 Apr 2004 06:50 pm
Autometer gauges PTGT Redman Turbo Performance 12 23 Jul 2003 09:08 am
