Squeeling noise ...
Old 17 Jun 2009, 06:45 pm
Arrow Squeeling noise ...
Im new here and could greatly use some help. Ive had the misfire code come and go but at the moment its gone .....
The problem now is I have this awful squeeling noise coming from the engine area... heres the kicker. It sounds like a belt but when Im driving it gets louder and louder .... any ideas?
Thanks,
Brant
Old 17 Jun 2009, 07:37 pm
Default Re: Squeeling noise ...
Ok we can work this through.
1. Does the noise happen continuously, or does it come and go?
2. Does the noise only happen while the car is in motion? Or does it also happen in Park?
Old 17 Jun 2009, 07:54 pm
Welcome.
Is your A/C on? Try turning it off.
Old 17 Jun 2009, 08:22 pm
Its on all the time !!! and gets louder when I accerlate
The noise is constant .. in park (I have a manual by the way) in gear not in gear ...
and to answer the last post it does it with the AC on or off
Old 17 Jun 2009, 09:25 pm
OK this helps. We can isolate it to the motor itself. Trannies (auto or manual) tend not to make noise, or if they do its isolated to a gear or it changes with different selections. No possible way its suspension, brake, or wheel related.
Best thing to do is open the hood and figure out which side of the engine bay its loudest.
In any event, the problem is likely to be a belt, failed bearing on an accessory (water pump/alternator, etc), glazed pulley or something like that.
Old 18 Jun 2009, 08:23 am
Sounds to me like its coming from the left (passenger) side of the engine area ... but sense they cover EVERYTHING under the hood its so hard to tell where all the belts and pullys are.
Why cant things be fixed like they useto .... A can of WD-40 and a swift kick
Old 18 Jun 2009, 08:31 am
That's a belt squeal.
All your belts, from your timing to your accessory belts are on the passenger side. Now the question comes, is it nearer to the front or the back, and top or bottom?
Old 18 Jun 2009, 09:03 am
That greyish or black cover you see on the passenger side only covers the timing chain. The accessories, belts and pulleys (water pump, alt, power steering, etc) are all visible if you remove the passenger front wheel and then the splashguard. Its not too difficult to do. Then you can check belt tension and play on the pulleys.
Old 18 Jun 2009, 10:54 am
Is there any other way to check than taking off the wheel?
Old 18 Jun 2009, 11:00 am
Brant, if taking off the wheel (and undoing the inner fender cover) is too much, don't even try and mess around with the belts. Let a professional do it. The whole front of the engine is accessible from the right side. You can try and take the inner fender of without taking the wheel but it's a PITA. What's the big deal about taking off the wheel?
Misdiagnosed noise + smell + overheating Orionid Tech & Performance Forum 2 04 Apr 2009 11:04 am
?? Noise From The Front :( hicomp Wheels, Tires, Suspension 7 17 Oct 2008 02:36 pm
Horrible shaking noise please help csd Tech & Performance Forum 9 05 Jan 2008 03:29 pm
Squeeling noise in rain... ucantcme General PT Cruiser Discussions 2 20 Aug 2007 02:18 pm
Road noise / exhaust noise in the car. jackatg450 Tech & Performance Forum 3 21 Jul 2004 10:55 pm
