Please correct if I'm wrong, but I'm reasonably sure that the 2.4L PT (as most auto engines these days) is a non-interference engine.
This means if you break a cam belt, you will not blowup your engine. The valves will not hit the pistons at any point in during the cam timing. The pistons are slightly dished and have valve pocket reliefs in the dome. Of course if your timing belt breaks, you're walking. But, you're not going to blowup your engine. |
Yes, your correct in part of what you heard. The valves won't hit the piston tops but the valves can hit each other. The only way to tell is with a compression check. Of all the owners that have had the timing belt break while they were driving, only two that I know of have had internal damage.
Valves hitting each other can't happen without something else very major happening. Without the belt, the valves won't be opening / closing anyway.
I know of one owner who went 190k miles before the timing belt let broke. I'm an owner that sticks to the maintenance schedule outlined in the owner's manual. I'm very particular about maintaining all my vehicles. The point is, that you're not going to blow up the engine simply because of the timing belt. |
PT Do-It-Your.net is a paid forum put together by expert mechanics to answer questions regarding the PT. Here's one of them.... I have a 2001 LE PT w/139, 544 miles. I was going about 40mph up a hill when the rpm's on the gauge dropped to zero. The oil and engine light came on. I applied pressure to the gas pedal and the car went no where. I checked the computer for faults and it indicated "no faults" so I'm pretty sure that the timing belt broke. What has to be removed to get to the timing belt? I know the PT has a non-interference engine, but do you think there could be any damage to the engine? - James, from Connecticut. Replacing the timing belt is a challenging job, which involves removing numerous components to access the belt. The service manual outlines the procedure in 25 steps, plus 6 sub-procedures. You will need a service manual, skill and the necessary tools and equipment to DIY. (The recommended service change interval is 90k miles under schedule B.) The PT engine is a non-interference motor, but only to a degree. Although the pistons will not hit the valves, the valves from both camshafts can hit each other. Valves hitting each other are very bad. One more thing. You say you know someone that went 190K before the timing belt broke, fine. I know someone o this forum that went 89K before his broke. Neither one proves a thing.
![]() ...just CREWZIN along! ® . . . PT Cruiser Links Moderator ![]() 2000 PT. Original Owner, 110,000 miles MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a Garage. Visit My Home Page www.CREWZIN.com Last edited by CREWZIN; 21 Jun 2009 at 06:15 pm. |
I understand the point of view.
What Russ has not seen is that the cams will continue to spin until the spring tension equalizes. Remember, I work on these motors every week. I just did another timing belt last Thursday. Sometimes you get lucky, other times the valves are bent. |
Oh, I see now. I was thinking of a SOHC. With the DOHC, each cam controls a pair of intake or exhaust valves per cylinder. The timing belt along with the cam index insures the synchronizing of the cam timing and thus keeps the valves from hitting.
Loose the belt (especially if you’re zinging it) and there is a possibility that the valves could hit. My bad and a good brain tease. |
Silver 2002 pt cruiser touring edition, auto, dark ass tint, 89k miles... shift burp mod, SRI 2005 civic ex special edition, 5spd, fully loaded, 40k miles I have a wide-band o2 sensor for sale!! PM ME!! |
| Engine swap / replacement compatibility | Brent72 | Tech & Performance Forum | 2 | 28 Jan 2009 07:23 pm |
| Headers for '04 2.4L 4cyl. engine. | owls_rayne | Tech & Performance Forum | 3 | 28 Nov 2007 03:11 am |
| Review: $2200 for a NA replacement engine PT | Ctown | General PT Cruiser Discussions | 8 | 24 Jul 2006 01:08 pm |
| 2.4l engine. | PTucker | Turbo Performance | 16 | 12 Dec 2003 08:50 am |
| Inside the 2.4L T engine - article | skylight | Turbo Performance | 1 | 04 Nov 2003 07:00 pm |
