PT Cruiser Forum Car Videos
Custom Wheels
Oil PSI Sensor
Old 08 Sep 2003, 11:29 pm
Bugdude21 Bugdude21 is offline
Default Oil PSI Sensor
I recently purchased an Oil Pressure gauge for my A-pillar pod and it comes with a sender that needs to be tapped into an oil line somewhere.
Has anyone else done this (hard to believe that someone hasn't) and where is the best spot to tap for the sender? The sender is a cylinder about 2" by 3" with a 1/4 x20 (I think) stem.....
Thanks in advance.
John
Old 09 Sep 2003, 02:18 pm
njsteve njsteve is offline
the location for the sender is located under the engine block on the right side. you need to drain the oil to remove the plug located on the block. you will also need a 3 inch pipe nipple to extend the sender away from the block because there is not enough room to install the sender.
Steve / Wayne, NJ
2005 GT Convertible Black on Black, Stage 1,
Blk Battery Cover, Mopar Stage 2 coilover kit, BTG Strut Bar, Eibach front and rear Anti-Sway Bar Kit, BOV valve,Magnecor wires, Mopar Dual Exhaust, 235/40/18 Sumitomo HTR Z II tires w/ Konieg Sideways Wheels Chrome Fuel Door Cover and Side Door Spears Covers, Tinted Windows, Blk/Red Coco Mats,
Old 09 Sep 2003, 09:12 pm
Cal Cruzer Cal Cruzer is offline
At least on the turbo model there is a plug in the driver's side of the head (acutally 2) that you can remove and use that hole. Not sure on the NA model
vB code is On
Check Engine Light came on - code 1188? coolvirus General Turbo Discussions 18 09 Jan 2008 01:14 pm
Error Codes skylight Tech & Performance Forum 6 07 Apr 2007 02:19 pm
Tranny She is a no-good! scottscars Stage Turbo Kits 15 16 Oct 2004 11:11 am
  MPAA | CreditCards | Loans | Horoscopes | Facebook Proxy
