instrument cluster checkout
Old 27 Jun 2009, 03:09 pm
Default instrument cluster checkout
Turning on the key while holding in the odometer button causes the instrument cluster guages and lights to go thru some sort of checkout procedure...does ayone have any detailed information on this? Thanks.
Old 27 Jun 2009, 03:44 pm
Default Re: instrument cluster checkout
Thats the built in test for instrument cluster <-> ECM function, as well as testing all the gauges. Any errors are listed at the end of the procedure.
Another test is the "key dance" - turn the key from lock to on (but not start) 3x quickly.
On-Off On-Off On-Off On
That'll read out any ECM trouble codes. Same info as a scan tool, except you need to find the code table - posted ALL over the place.
Old 27 Jun 2009, 03:51 pm
.....and if there's no codes stored in the computer, the dial with read "done".
Factory Instrument Cluster bulbs Replacement? I Need HELP! HotToyz Interior Accessories Forum 2 20 Sep 2008 08:32 pm
Instrument cluster goes dead kwells44 Tech & Performance Forum 1 17 Jul 2008 02:18 pm
Instrument Cluster LAmps - Update . . Nickatnite General PT Cruiser Discussions 1 22 Dec 2007 06:28 pm
dash/speedometer lighting tomctomc General PT Cruiser Discussions 7 09 Dec 2005 11:44 am
