Transmission Issue?
Old 03 Jul 2009, 11:03 am
Default Transmission Issue?
I have an 08 Touring with about 10,000 miles. At times I can feel the car shake and not sure, but feels as though it's coming from the middle of the car I guess. It's almost like a sensation when you are driving a manual and slow down and don't down shift and the car starts to shake. It only lasts for about 1-2 seconds and seems to only happen if I'm driving up an incline at a certain speed I guess. Sorry, lot of guessing here because it happens very seldom and difficult to make it happen again to try to figure it out. Anyway, was concerned if I let it go it could turn into a larger problem and wondering if anyone has had this before before I take it in or if it may be transmission issues which I've read seems to be a problem with the PT when searching for similar symptoms.
Old 03 Jul 2009, 12:05 pm
Default Re: Transmission Issue?
The auto transaxle is a known weal link in the drive train but haven't heard of any going out with your kind of mileage. Any other symptoms besides that? Rough idle, a skip or miss when accelerating? Sounds almost like your in the wrong gear like you said with a manual trans. I can't find anything in a search except a shake right before you come to a stop.
Try re-setting the computer by taking off the negative battery cable for about 5 minutes. This clears any codes (if you had any) and makes the computer learn the original settings once the cable is put back on and you go for a ride. Can't hurt. It's like re-booting your computer at home.
Old 03 Jul 2009, 12:14 pm
IMHO, I would take it to the dealer and discuss it with them. It then will be documented for later if necessary.
Old 03 Jul 2009, 01:23 pm
Thanks guys, I've basically already done the reset of the computer since I've been working on installing a new amp, etc. Other than the rare occasion of this happening, everything runs perfectly fine.
I bought the car used with 5,000 miles and I remembered it happened once when my dad was driving the first week of getting it. But at that time, I assumed it was just something on the road since it was so quick and there was some road construction on the road. Did not happen again for quite some time after that and has only happened maybe 6-7 times total. Anyway, I'll take it to a dealership and see what they say, but I always like to try to get an idea before going in just in case they try to BS me
Old 05 Jul 2009, 01:15 am
have someone check the rear trans mount ,maybe cracking from hard take offs or maybe hard downshifts.Good luck,Ray Newton Pteazer.
Transmission problem Syl General PT Cruiser Discussions 4 20 Sep 2008 09:50 pm
Transmission question scottbirge General PT Cruiser Discussions 5 28 Jun 2008 06:50 am
Transmission Plant Drives Optimism skylight PT Cruiser News and Rumors 3 27 Jun 2007 02:14 pm
Transmission issue... MDCruiser Tech & Performance Forum 10 06 Mar 2006 08:14 pm
A Few Thoughts On The Mopar Issue Steve03GT Turbo Performance 10 12 Jun 2003 05:36 pm
