Rough idle 03 GT
Old 03 Jul 2009, 02:22 pm
Default Rough idle 03 GT
Changed plugs & wires Champion plugs 470 (RE14MCC5) .40 gap NAPA Belden Max Wire Set. Still running rough. As stated in many posts the coil pack dosen't fail very often. Will clean throttle plate next. My question is will i need a new gasket?
Old 03 Jul 2009, 08:17 pm
Default Re: Rough idle 03 GT
Not sure about the gasket but you should be able to clean the throttle plate with a couple squirts of throttle body cleaner while the throttle body is still attached, also on the back of the TB is an electrical connection to the IAC (Idle Air Controller) that can be a source of a rough. idle. It can be taken off and cleaned.
Old 03 Jul 2009, 09:44 pm
Thanks Crewzin, will give it a try tomorrow.
Stalling, rough idle, running "hard", hesitation LiLOrion Tech & Performance Forum 36 21 May 2013 12:43 pm
New PT but rough idle?? Ed Tech & Performance Forum 9 05 Mar 2013 06:38 am
Help Rough Low Idle almost cuts off.. lockupman1 General PT Cruiser Discussions 14 05 Jan 2011 01:28 pm
Intermitent rough idle argos587 Tech & Performance Forum 9 23 Mar 2009 07:29 pm
Ran out of gas....got rough idle now! garpike Tech & Performance Forum 12 06 Aug 2008 04:21 pm
