key on board programming
Old 07 Jul 2009, 09:23 am
Default key on board programming
Well, succesasfully cut and on-board programmed a new transponder key blank for my 08 PT. However, the programming procedure did not go exactly as per the owner's manual. Never got a chime when the security light stopped flashing after the first time the new key was inserted and turned on. The new key did start the engine the next time it was turned on and it kept running fine but then the security light came on and flashed a while then the light turned off with a single chime. Next attempt to start with the new key was fine...no flashing light this time. All appears to be OK but just wonder if anybody has a better or different or updated procedure than what is in the owner's manual that works as it should for them. Thanks.
Old 07 Jul 2009, 09:37 am
Default Re: key on board programming
Here's some stuff to read. Don't know if it will help.
New remote programming
Old 09 Jul 2009, 09:18 am
Checked several other Chrysler vehicle-specific forums regarding this matter and found that others are having problems with on-board programming per the owner's manual when they get to the last step with the new key. Must have just got lucky in my case because it did not go exactly as per the manual but did work in the end.
Old 09 Jul 2009, 09:30 am
That's all that counts.
Arts take a back seat under Baraboo School Board - Baraboo News Republic skylight PT Cruiser News and Rumors 0 13 Apr 2007 11:00 am
was the board down today ?? bobs turbo pt Non-PT Discussions 5 19 Jul 2006 07:50 pm
Cost of a used surf board??? patbluecruiser Southeast PT Forum 3 13 Jan 2005 09:36 pm
one year on the board!! bobs turbo pt Non-PT Discussions 5 17 Dec 2003 07:17 pm
Hello, new to the board...photos added tomdenise General PT Cruiser Discussions 26 18 Nov 2003 12:59 am
