Replacing Ignition Lock Cylinder--Done
Old 13 Jul 2009, 12:08 am
Matt42's Avatar
Thumbs up Replacing Ignition Lock Cylinder--Done
I replaced the ignition lock cylinder on my 2001 yesterday. It took about 10 minutes, before breakfast.
Here's the process from the factory service manual, with some annotations. It is not necessary to remove the steering wheel. It requires having a serviceable key and the lock cylinder has to be capable of being manipulated into the RUN position.
quote
REMOVAL
(1) Disconnect negative battery cable.
(2) Place key cylinder in RUN position. [This took some manipulating due to the cylinder's condition.] Through the hole in the lower shroud, depress lock cylinder retaining tab and remove key cylinder. [I used a No. 2 square drive screwdriver.]
INSTALLATION
(1) Install key in lock cylinder. Turn key to run position (retaining tab on lock cylinder can be depressed). [As simple as it sounds.]
(2) The shaft at the end of the lock cylinder aligns with the end of the housing. To align the socket with the lock cylinder, ensure the socket is in the run position. [The socket is the place in the steering column that the cylinder fits into. If you didn't disturb the electrical part of the assembly, it is already aligned.]
(3) Align the lock cylinder with the grooves in the housing. Slide the lock cylinder into the housing until the tab sticks through the opening of the housing. [Actually, you will feel the -snap- as it engages.]
(4) Turn key to the OFF position. Remove the key.
(5) Connect negative terminal to battery.
end quote.
It's on page 8D-11 of the factory manual. It's way simpler than it seems like it should be. The last time I did this, it was on a 1993 Saturn SW2, and it took two hours. And required removing the steering wheel. The worst part was $157 for the new cylinder for the PT, keyed to match, at the dealer. Beats getting stuck not starting at 115F outside. Or the price of a tow.
1996 Dodge diesel 4X4, 2001 PT Cruiser Touring with rear disc brakes, [Now gone 2004 PT Cruiser Base 5 speed], 2007 Chrysler T&C Touring
Last edited by Matt42; 13 Jul 2009 at 12:10 am. Reason: found a typogographical eror
Old 20 May 2010, 08:58 pm
Default Re: Replacing Ignition Lock Cylinder--Done
10 mins? that's all it took? my so called mechanic friend did my ignition lock cylinder for 40 mins. lol.. nice write up. Could've been better if coupled with pictures.
Old 20 May 2010, 10:10 pm
Matt42's Avatar
Would have taken 1/2 hour to find the camera. Then it was mostly done by feel.
02 pt ignition lock anttwan Tech & Performance Forum 2 30 Aug 2008 10:09 pm
Yes/No in replacing ignition coils on a GT crazie.eddie Tech & Performance Forum 8 01 Nov 2004 01:55 pm
