Removing rear wiper.
Old 15 Jul 2009, 09:36 pm
SoCalCruiser's Avatar
Default Removing rear wiper.
I was able to remove the nut under the plastic cover on the outside...I pulled a few times with no luck. Do i have to remove the motor on the inside before removing the wiper arm on the outside?
2006 Limited Edition, 2.4L 4-Cyl DOHC 16V SMPI Engine, Magnesium Pearl Coat Paint, AirAid Intake, NGK Plugs, Crane Wires, Freedom Design Strut Bar, front and rear eibach lowering springs & sway bars:-)
Old 16 Jul 2009, 05:12 am
Default Re: Removing rear wiper.
No, the arm is pressed on so use something for leverage, plenty of towels so you don't scratch anything and pry it up gently.
Old 16 Jul 2009, 07:48 am
I couldn't get mine off that way,was afraid I was going to break something.I made a little puller to get mine off.Made it out of two pieces of inch angle iron welded together in a "U" shape.In one side of it,I drilled a hole and tapped it 5/16ths.In the other side,I made U shaped hole that slide under the wiper and you just tighten down the bolt and it pulls the wiper right up.
Old 16 Jul 2009, 08:12 am
The thing I was trying to get across is that after the center bolt is out, there's nothing holding the arm on except the tightness of the wiper arm itself. Your tool sounds great for that kind of job.
Old 16 Jul 2009, 03:35 pm
Ok.. I will give it another try when i get out of work. Thanks for the help.
Old 16 Jul 2009, 10:05 pm
Finally removed the wiper arm. Thanks for the help.
Rear window glass without wiper hole? NMdesertracer General PT Cruiser Discussions 1 04 Apr 2009 07:54 pm
rear wiper problem rrgsj Tech & Performance Forum 4 21 Mar 2009 07:32 pm
Rear Wiper Motor stopped oshawa Tech & Performance Forum 5 14 Sep 2007 09:06 am
Rear Wiper Shave SUCCESS!!!!! ptcruzin42 Exterior Accessories Forum 2 23 Mar 2003 10:58 pm
