oil pan bolt
Old 16 Jul 2009, 05:38 pm
demon666's Avatar
Default oil pan bolt
well i tryed to cheange the oil my self firt time on my 2004 PTC and failed to remove the blot on to tight? done by inpact gun ? i perty much striped the bolt it self it was bran new..
Will have to buy a new one for the record to take it off its counter clock wise right??
Old 16 Jul 2009, 07:09 pm
Default Re: oil pan bolt
"Righty Tighty, Lefty Loosey" You are talking about the oil pan drain plug, right? Was the plug to tight to start with, normally a impact gun is NOT used on that plug as it is to easy to strip out. If that happens, you'll need to get an oversized oil pan plug.
Old 16 Jul 2009, 07:21 pm
Get socket on it perfectly, and give a sharp rap on the socket handle. I've had it hard to free sometimes, too. You have to "crack" it.
Does everybody talk that differently in Alaska? I could understand Sarah Palin when she was on the tube.
If the bolt was that tight, you didn't strip it. The moron that put it on did. Probably had arms like an ape. Hooligan is right; you'll probably need an oversized plug or worse, you'll have to drill a new bigger hole.
Old 17 Jul 2009, 05:58 am
BeerBurner's Avatar
The first time I changed the oil in my wife's Cruiser I ran into a stuck bolt. I eventually got it off with enough swearing but the head of the bolt twisted and bent a little bit and is, to this day, still stuck on the socket head. I replaced it with an aftermarket bolt that had a larger head and haven't had a problem since.
BB.
'87 Porsche 944 (my toy)
'90 Miata (my daily driver)
'04 PT Cruiser (her's)
"Sometimes you're the windshield... sometimes you're the bug."
Old 17 Jul 2009, 06:03 am
Travis2k7's Avatar
I LOL'ed.
Things are perty down here in Georgia too man... I remember when I moved down here from NY and visited my first Waffle House...
I was like "What's this over here?"
The guy says "You've never heard of grits?"
I was like "Sure, I've heard of grits, I've just never actually seen a grit before."
2006 Limited, Auto, 100k miles
Old 17 Jul 2009, 06:36 am
Alex_Clarke's Avatar
I'm pretty sure he talks like that cause he's a Satanist Hillbilly. Or should I call it a Snowbilly.
The only reason I say that is cause he lives in Alaska, hence the snow part
The billy part comes from the fact that in his picture he is holding what looks like a fully-automatic AK-47. Illegal in the United States.
He looks like he's sitting in a lawn chair and he is using a milk crate as a table.
The satanist part comes from just the fact that his name is demon. (Devil) and the 666 obviously a satanist. lol
I'm just kidding.
Driver:Alex
Car:Petey
2006 Inferno Red PT Cruiser Touring Signature Series, 38K, 15mpg, Automatic.
Exterior:American Racing Estrella 16s, Toyo Proxes TPT, ROL Xtreme Exaust Tip.
Interior:Bumblebee BobbleHead, 2 6x9s, pioneer ts-g1640r's in doors, Parking Permit for my schoool.
Performance:Custom Air Intake, NGK Platinum plugs, Ceramic Brake Pads, Duralast 7.5mm coil wires, Duralast Performance rotors.
Old 17 Jul 2009, 12:22 pm
First mistake is using a socket. You should use a rachet wrench. They never slip and work well.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 22 Jul 2009, 12:32 pm
demon666's Avatar
funny I do live in Alaska I work on a 301 foot barge in Dutch harbor ak my job is ships security among other duties that is a full auto AK and its legal i payed my 200 tax stamp only in AK love my job.
Bye Bye wheel bearings turbomangt General Turbo Discussions 71 18 Jun 2017 08:32 pm
Lower control Arm Bushings BOLT Madturtle Tech & Performance Forum 3 10 Jun 2009 02:00 pm
Photo of clutch adjustment bolt? Dirk_Gently Tech & Performance Forum 1 25 Sep 2008 06:37 pm
Problem with a wheel bolt Striker Wheels, Tires, Suspension 13 17 Aug 2006 05:27 pm
Need help fixing a lug bolt. KurtPT Tech & Performance Forum 4 12 Aug 2003 06:03 pm
