Engine rebuild. Advice...
Old 18 Jul 2009, 10:49 pm
Default Engine rebuild. Advice...
I've decided to rebuild the engine and do some custom items on it like the intake, headers, etc... What I want to know is, while I'm rebuilding the engine, is there any way i can amp up the compression ratio cause I'm looking at the sebring and patriot's I-4, they have a 10.5:1, while us PT lovers are stuck with 9.5:1. And I've researched it and they have a different bore X stroke than the PT, and the displacement is different too, 2360cc sebring, 2429cc PT. So parts I'm looking for are obviously aren't going to be an easy engine swap bit. So what do I do?
Old 18 Jul 2009, 11:25 pm
Default Re: Engine rebuild. Advice...
You can have a shop "shave" the head - mill some off the head - that'll raise compression ratio.
While you're at it, get turbo connecting rods - they're stronger.
Old 19 Jul 2009, 03:46 am
I hope your talking about milling off the top, cause milling off the side would widen the gap between the head and the cylinder wall.- It's an 01, with 101k miles, are the turbo lifts gonna be easy to swap transfer over to a non-turbo engine?
Old 19 Jul 2009, 03:49 am
What about the camshafts, any chance at finding some performance ones, or am I going to have to pull them from a neon? are the connecting rods from the turbo going to be the same length as the non-turbo?
Old 19 Jul 2009, 07:19 am
If you're serious, you should go to PTCrew.com - Learn it or Burn it. - there are more gearheads there who have gone inside the engine.
Most of us here know our limits....
Engine swap / replacement compatibility Brent72 Tech & Performance Forum 11 19 Dec 2013 09:18 pm
Engine rebuild gpow General Turbo Discussions 3 05 Jun 2009 06:03 pm
Need some advice-Problems with my replacement engine Abgmauldin Tech & Performance Forum 11 16 Feb 2009 09:14 pm
"Mysterious" turbo engine noise...??? Gary04GT Turbo Performance 76 21 Aug 2006 08:28 am
Review: $2200 for a NA replacement engine PT Ctown General PT Cruiser Discussions 8 24 Jul 2006 01:08 pm
