Transmission Maintenance
Old 23 Jul 2009, 12:35 pm
SoCalCruiser's Avatar
Default Transmission Maintenance
My 06 LE Cruiser hit it's 62,000 mark this weekend. I just received a quote from the dealer to drop, replace filter, and adjust something in the tranny for $220.00.... Is that a reasonable price? I remember getting a coupon in the mail months ago that said it can be done for $90.00.. I'm going through all my old mail and papers looking for it. What do you guys think??
2006 Limited Edition, 2.4L 4-Cyl DOHC 16V SMPI Engine, Magnesium Pearl Coat Paint, AirAid Intake, NGK Plugs, Crane Wires, Freedom Design Strut Bar, front and rear eibach lowering springs & sway bars:-)
Old 23 Jul 2009, 01:34 pm
Travis2k7's Avatar
Default Re: Transmission Maintenance
Seems a bit high.. but it's a dealer so it's expected.
I recently had my tranny flushed and got a new filter at the local reputable transmission shop and it was $149.
2006 Limited, Auto, 90k miles
Old 23 Jul 2009, 02:37 pm
Yep, I got a deal because the owner of the Chrysler dealer also is the sponsor of my Corvette club. He gave me $50.00 off and to flush the whole system of the PT was $110.
Old 23 Jul 2009, 04:21 pm
I found the coupon...Automatic Tansmission Tune-up Service- New Mopar filter, new fluid and necessary adjustments for $84.95 . The only problem it expired last month & the dealer it's from is not there anymore. I'll try and convince the dealer down the street to honor the coupon. Wish me luck.
Thanks for the information Travis2K7 & Crewzin ($110.00 to flush the system? are you talking about a radiator flush?) I need to do that too. I'm starting to notice a black/brown ring in the overflown tank.
Old 23 Jul 2009, 05:05 pm
mopar_man's Avatar
You COULD change the fluid and filter yourself but you would get all the old fluid out of the torque converter. They've got a machine to do that, hence why it costs more. The coolant you can do yourself though. Drain what you can from the petcock on the radiator, run some distilled water through it, drain, run water through again, drain and top up with fresh coolant. The best way to get the proper ratio of water to coolant is to take note of how much water you drained from the system. If memory serves correct, you need 7.5 quarts of coolant for the whole system.
1973 Barracuda
340/auto
Modifications: Too many.
2002 PT Cruiser
N/A 2.4L/5-speed
1989 Caprice Wagon
307/auto
Old 23 Jul 2009, 05:18 pm
I hope at 62k this isn't your first tranny service.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 23 Jul 2009, 10:50 pm
I'm embarrassed to say this is my first tran.. service. I know I'm looking for trouble by doing that. Its one of those things that i have put aside because i don't know how to do it myself. This is the only part of my baby i have neglected in the past two years I've owned her.
Old 23 Jul 2009, 11:14 pm
soonercruiser's Avatar
Cool Re: Transmission Maintenance
Beg...get your best deal.......get it done!
That's my problem...every time I have to search for a coupon; it's expired!
Frank, aka SOONERCRUISER,
Old 24 Jul 2009, 06:17 am
Travis2k7's Avatar
Yeah the tranny is a weak link and you are definitely asking for trouble.
I bought mine at 45k and while the car checked out great I didn't get any maintenance records from the prior owner. (It was a lease car so I'm assuming it was maintained but you never know)
Anyway, I changed the plugs/wires, rotated tires, changed oil (synthetic) and had the tranny flushed (a total flush with the machine)... It's called peace of mind maintenance and guess what? It still had the original plugs/wires!
6000 miles since I bought it and the car has been flawless... AC is ice cold and I've had no issues other than a $25 O2 sensor.
Old 24 Jul 2009, 10:33 am
mopar_man's Avatar
Oh boy. Never assume a lease is maintained. Most folks leasing don't plan to keep the vehicle. A few years ago, a guy on a different forum I belong to bought a used Durango that was a lease. I don't remember what the problem was that he was having but he had to remove the intake. The lifter valley underneath was SOLID sludge. The vehicle was never maintained.
EDIT: Not to scare you, that was probably one of the most extreme situations I've seen. I'm just saying to never assume anything and you didn't by doing all that maintenance on it.
1973 Barracuda
340/auto
2002 PT Cruiser
N/A 2.4L/5-speed
1989 Caprice Wagon
307/auto
Manual Transmission Fluid Change matt87951 Tech & Performance Forum 22 11 Apr 2011 03:42 pm
'02 Limited edition Automatic transmission woes RhetRx Tech & Performance Forum 5 12 Mar 2009 10:18 pm
Transmission problem Syl General PT Cruiser Discussions 4 20 Sep 2008 09:50 pm
Transmission Plant Drives Optimism skylight PT Cruiser News and Rumors 3 27 Jun 2007 02:14 pm
Transmission fliud - B&M Trick Shift or not? snakepitt1 Tech & Performance Forum 8 22 May 2004 06:58 pm
