rear end suspension problems
Old 26 Jul 2009, 09:55 pm
Send a message via Yahoo to partyd
Default rear end suspension problems
I just purchase a 2002 limited with 50k miles this vehicle was park for a year
i drives ok no problem until the car goes into a hole or speed bump, and looks like i lost one rear tire and the trunk shakes very bad, or the car jumps like 4 times when going into a small hole
It also sound like a lose spare tire, but i remove it and test again same problem
can the bushings be bad or the shocks are gone ? the miles are low in this vehicle
any ideas ? thank you
2004 pt cruiser gt
2004 chrysler 300m
2004 town and country
Old 26 Jul 2009, 10:02 pm
Sharkstooth's Avatar
Default Re: rear end suspension problems
If you want to drive up this way i can look at the bushings for you and see if they are bad but most likely the problem is in the tires from sitting a long period of time without being moved thus forming flat spots on them.It is also poss that the shocks are bad,but hard to say without seeing it.
Old 26 Jul 2009, 10:16 pm
forgot to mention i switch the tires and driving on a good flat road there is no problems, only when there are bumps holes or problems on the road
2004 pt cruiser gt
2004 chrysler 300m
Old 26 Jul 2009, 10:26 pm
Then it is definately your shocks but i would check those bushings.Have a mechanic look at it to make sure,just take it to someone you know.good luck.
Old 27 Jul 2009, 11:05 am
Sounds like the bell crank for the watts link. I had to replace it on my buddy's cruiser.
Old 27 Jul 2009, 09:37 pm
today i pull the shocks and they look ok ,
how do i know if they are bad ? i can push it in agains the floor and they go in and if i release it comes out slow
bell crank, is that thing in the midle ? how do i know if is bad ?
thnk you
2004 pt cruiser gt
2004 chrysler 300m
Old 28 Jul 2009, 06:43 am
thnk you
See if this helps...
How to Check the Condition of Your Shocks: How to Replace Your Shocks | eHow.com
Old 28 Jul 2009, 09:25 am
thank you crewzin, my shocks are good ,springs look good so
it looks like i have to replace all he bushings and see if it stops
2004 pt cruiser gt
2004 chrysler 300m
Alot of front and rear suspension squeeks? 1lowufo Wheels, Tires, Suspension 5 31 Oct 2008 05:54 pm
Suspension problems VTPTlover General PT Cruiser Discussions 16 17 May 2007 01:48 pm
Suspension Techniques Sway Bars For the GT Turbo Gear_Head Turbo Wheels/Suspension/Handling 2 12 Sep 2003 02:51 am
Complete Rear Suspension with Drum Brakes yellowpanel Classifieds: For Sale/Trade 0 09 Aug 2003 01:37 pm
