I haven't had a chance to put the new plugs in...but is it a possibility that during the stint of time that the cooling fan did not work, that if the pop-off valve on the AC compressor went off and released freon multiple times, that the freon is low on the low side and the ac compressor doesn't like it? Just a blind shot in the dark because I notice the rough idle when the AC compressor is kicked in. I won't say that it isn't there when the AC compressor is not on, but it is very evident in that I can see the hood shaking when the AC compressor is on.
The car will idle steadily at 700-750 RPM all of the time, so I don't think it's the IAC (I've cleaned it anyway) or an injector problem(would notice that more on takeoff). How about EGR issues? I kow my old Fords would darn near die if the EGR valve went bad.
2005 PTC Limited N/A- All Stock...for now 2003 Hemi Ram - TMR, Flows, Killed the Cat with mechanical O2 sim, K & N, no hat, Taylor Shorty Wires, Tow Pkg |
Took a while...but I finally got back to working on the car. Been way too busy at work the last couple of weeks.
I went ahead and changed the plugs, wires and PCV valve. I installed Champion Platinums, Borg Warner wires, and and oreilly's brand PCV valve. I went ahead and gave her an oil change and air filter while I was in there. All of this is now new, complete and right, and there was NO change in the idle. I did notice that the upper and lower motor mounts were completely shot, so I am off to oreilly's to pick those up too. When I got the mounts off to inspect, both of them fell apart in my hands. Maybe that's it? Not sure...we'll see in a bit. How hard is it to change out the center mount on the drivers side? I'm starting to think that at only 52k I'm gonna have to replace the timing belt, so maybe I'll do it then. ![]() ![]() On edit: It seems that the motor mounts being bad were not the cause of the shake. New upper and lower mounts have been installed, and the shake is still there. Please keep in mind that the idle is not erratic, and it is not missing erratically. It is a constant shake that disappears off of idle. This is really starting to frustrate the heck out of me...
2005 PTC Limited N/A- All Stock...for now 2003 Hemi Ram - TMR, Flows, Killed the Cat with mechanical O2 sim, K & N, no hat, Taylor Shorty Wires, Tow Pkg Last edited by 03hothemi; 08 Aug 2009 at 01:24 pm. Reason: I wanted to... |
I was really hoping to see you fix this because my son's '05 does exactly what yours does. I have replaced the lower mount, PCV, plugs (although I used Bosch quad tip), wires, air filter, checked the same as you for vacuum leaks, etc.
His also does not miss, it's just a rough idle and it gets much worse with the A/C on. One thing in common maybe is that I noticed the A/C cycles a lot and I'm thinking it could have had a leak somewhere along the way and possibly is low on juice. Like yours, his has no other driveability problems whatsoever. Gets 23 combined, acceleration is probably as good as the 2.4 Non turbo gets. However, his actually will die if let alone to idle with the A/C on but it takes a few minutes. Now one thing I noticed is that with or w/o the A/C on, if I decel fast, for instance if it's in gear and I were to hold the brake and raise the throttle, then let off suddenly, it wants to die. Other than that, as soon as I see yours get fixed, maybe I'll know the answer to his. |
The only difference between yours and mine it seems would be that yours tends to die. Mine never has.
As soon as I get the front end rebuilt on my Ram, and get her back on the road, I'm gonna tear into the PT to see if the timing belt needs to be replaced. Other than that, I have no codes or other diagnostic tools to work with. Maybe its an injector imbalance or catalytic converter starting to clog...hmmmmmmm...what a pain.
Seems like this has been quite a problem for many on here. I'm thinking has anyone ever gone to the dealer and addressed this problem? I have a 2005 GT I bought about a month ago with 61k miles and have the same problem. I replaced the wires and plugs and that did nothing. It does idle smoother with the a/c off. I notice that rpm doesn't drop at all with the a/c on or off so it's not an idle too slow thing. I'm thinking of taking the accessory belt and running the car for just a moment and see if there's something in that area that could be causing the problem. Anyone have any ideas to this?
fljohnboy, the problem as I see it, is that people ask questions about problems, find the answers and they never return to tell what the outcome is!!!
![]() It certainly doesn't help the ones that tried to help as well as those that may have the same problem.
![]() 2008 Silver Steel Metallic, Touring, NA, Sirius; Chromed door handles; lower grille; fog light surrounds; chrome front & rear bumpers strips; Airaid air filter; Bassani duals; Modesty Cover; Autolite AP5263 Platinum Plugs (.040); Crane Plug Wires; NAPA Ceramic pads; Blane hood struts; PTeazer Gas, Brake & Foot Rest Pedals, '05 Rear Step Pad, Stainless Door Sills, Llumar tint, "A" Piller chrome; APC Strut Bar |
Yep, totally agree. I've been on different forums with different cars over the years and that's the way it seems to be. |
| Help Rough Low Idle almost cuts off.. | lockupman1 | General PT Cruiser Discussions | 14 | 05 Jan 2011 01:28 pm |
| New PT but rough idle?? | Ed | Tech & Performance Forum | 6 | 03 Oct 2009 08:03 am |
| Overheating during Idle only?? | CaPTuredCruiser | Tech & Performance Forum | 2 | 13 Nov 2008 10:12 pm |
| Stalling, rough idle, running "hard", hesitation | LiLOrion | Tech & Performance Forum | 35 | 30 Dec 2007 10:41 am |
| RPM Idle in D after S1??? | Steve03GT | Stage Turbo Kits | 3 | 12 Sep 2003 06:55 pm |
