I don't believe it would cause bad idle, but what did you gap plugs at? Should be 0.040 Do a search on IAC (Idle Air Controller) - try cleaning that.
I agree with QSD, especially the plug gap. The stickers on the car say .050in but Chrysler came out with a Technical Service Bulletin (TSB) telling everyone to drop the gap to .040 which would solve a whole host of problems.
Also as QSD noted, the Idle Air Controller (IAC) located behind the Throttle Body can be taken off and cleaned or just replaced. Dirt can accumulate in the IAC and hurt the idle.
The 'Tailor mag' I referred to in my first post are the wires. I haven't tried to change the Coil yet.
I pulled and cleaned IAC valve this evening...to no avail. Gonna go pull plugs and check gaps, but I thought I gapped them at .040. It's worth a shot.
2005 PTC Limited N/A- All Stock...for now 2003 Hemi Ram - TMR, Flows, Killed the Cat with mechanical O2 sim, K & N, no hat, Taylor Shorty Wires, Tow Pkg |
Damn. You've covered all the common causes.
![]() Other thoughts: Motor mounts - I've read of some failing. There are counterbalance weights in the crankcase - driven by chain - could that have broken? How bad was the overheating you had? Did you lose coolant? Did gauge go into red? I'm thinking minor head gasket leak... One or more injectors could be acting up - there's a "spray pattern" test that can be done - don't know what that costs... Dunno... Last edited by quicksilverdon; 28 Jul 2009 at 08:39 pm. Reason: more thoughts |
You said you fixed the overheating problem by replacing the fan,but did you replace the head gasket.It is possible that you have a leaky head gasket causing the idle miss and if you think about it when it warms up the aluminum expands and the leak becomes worse causing it to run worse.The reason why i say this is because i had a car that did this and did not show signs of it like smoking or smelling like antifreeze,than all of a sudden it got worse and would go through a gallon of water a day and still would not smoke and had no water in the oil and the car still had great power.When i took my camaro apart,it was leaking out of a little water jacket hole in the head gasket.I put back together and the Idle problem and losing water where fixed.I know these are two different cars but the same concept,good luck.
I've considered motor mounts being bad. The only problem I see with that is that the motor itself shakes, but it never shook this much at all. Failing motor mounts would tend to transfer what I believe to be much more of the roughness into the car than what is actually occurring. By the way, how much should the motor move when the car is put into gear? I really hope that internally this motor is sound. I would suspect that if counterbalance weights were off that I would feel the vibration throughout the entire range of RPMs, not just at idle. Once the car comes off of idle, it is perfectly smooth. No hitch in it's get-a-long whatsoever. The car never actually overheated in the since that it ever lost coolant. The gauge never went red. I have to say, my wife keeps a pretty sharp eye on her gauges. And, I have noticed no coolant loss in the past few months, other than what was lost and replaced during the fan replacement. Funny thing...the sticker on the car says .040. When was the plug gap spec changed? Just out of curiosity more than anything. I just re-gapped the plugs. All of them were at .060 plus. It looked like the plugs have been in there for 100k but I know damn well I put a new set in last summer. Oh, and by the way, I lied earlier. I put champion plats in my truck, and autolite plats in the PT. I'm gonna go later this week and buy a new set of champs for the PT and see if that solves the issue. I did notice that after setting the gaps between .038 and .040 that the idle did somewhat smooth out, but is still rougher than my friends 06. Any other ideas?
![]() Oh yeah...my wife says I need to put a pic of her car up here, not my truck
2005 PTC Limited N/A- All Stock...for now 2003 Hemi Ram - TMR, Flows, Killed the Cat with mechanical O2 sim, K & N, no hat, Taylor Shorty Wires, Tow Pkg Last edited by 03hothemi; 28 Jul 2009 at 08:52 pm. |
Here's one check for the head gasket without tool requirements: let the engine cool to stone cold. Remove the radiator cap and start the car. See any bubbles in the coolant? Besides doing the pressure check, you might want to borrow a compression tester. You sure have pulled up a dandy problem here. It'll be interesting to see what it finally ends up being.
1973 Barracuda 340/auto Modifications: Too many. 2002 PT Cruiser N/A 2.4L/5-speed Modifications: Boogers, Maddog 80% STS, Auto throttle body, Airbox modifications, Eibach Pro springs, Energy Suspension control arm bushings & motor mount inserts, disabled balance shafts. 1989 Caprice Wagon 307/auto Modifications: Lowered 2" front and rear, flat black paint, emblems and trim removed and filled, pinstriping, big 'n little tires. |
| Help Rough Low Idle almost cuts off.. | lockupman1 | General PT Cruiser Discussions | 14 | 05 Jan 2011 01:28 pm |
| New PT but rough idle?? | Ed | Tech & Performance Forum | 6 | 03 Oct 2009 08:03 am |
| Overheating during Idle only?? | CaPTuredCruiser | Tech & Performance Forum | 2 | 13 Nov 2008 10:12 pm |
| Stalling, rough idle, running "hard", hesitation | LiLOrion | Tech & Performance Forum | 35 | 30 Dec 2007 10:41 am |
| RPM Idle in D after S1??? | Steve03GT | Stage Turbo Kits | 3 | 12 Sep 2003 06:55 pm |
