Trans. fluid level fluctuates!!!!
Old 28 Jul 2009, 05:47 pm
Question Trans. fluid level fluctuates!!!!
I had the trans. fluid & filter changed about six weeks ago and the shop put two qts. extra in. I took it back a couple days later and they siphoned it out. I checked the fluid level hot every day the following week and it was a tad high (just below the notch in the dipstick, no big deal). I decided today to check the level hot and it read three qts overfilled and very foamy but red. I checked it two more times and it was still three qts over and foamy. I drive home a few miles and checked it again and it read three qts over and foamy but when I let the car idle for a minute the fluid level was perfect with no foam. What the heck is going on? I always thought you could just check the trans. when hot and idling and it should be accurate. Outside temp. was 90* & humid and she shifts fine.
66CUDA
Old 28 Jul 2009, 06:28 pm
Default Re: Trans. fluid level fluctuates!!!!
There's a procedure to check the level, like run thru the gears or some such - read up on it.
Old 28 Jul 2009, 06:58 pm
Did that...I moved the shifter thru each gear position for three seconds and back into park while on a level surface. I've checked plenty of tranny's in my time and this the first time this has happened.
66CUDA
Old 28 Jul 2009, 07:21 pm
66CUDA
Sorry then.
Could there be air in the tranny? Causing the foaming?
Old 29 Jul 2009, 12:57 pm
geronimo's Avatar
Did you trans fluid look like this?
Cuz it might be slime... and you might be a ghostbuster.
2003 Touring Edition. 65k
Here's to a long life and a happy one.
A quick death and an easy one.
A pretty girl and an honest one.
A cold beer and another one!
synthetic trans fluid ok? 85_305 Tech & Performance Forum 11 24 Jul 2009 11:41 am
TRANS FLUID DARK270 General Turbo Discussions 10 31 Jan 2005 05:29 pm
Shocks/Struts and Trans Fluid 1lowufo Tech & Performance Forum 3 04 Nov 2004 02:15 pm
Coolant Fluid Level Ed Lim Tech & Performance Forum 2 28 Sep 2003 07:38 pm
ATF+4 auto trans fluid finally available MX-5 Tech & Performance Forum 3 04 Sep 2003 01:20 am
