Install - Oil Pressure Sensor
Old 29 Jul 2009, 10:24 am
geronimo's Avatar
Default Install - Oil Pressure Sensor
Has anyone put one of these in their cruiser? Where is it? Can I do it myself?
The Chilton's manual doesn't show anything relating to this sensor. Dealer wants 30 bucks to put it in so I assume it's not that hard to find and install.
2003 Touring Edition. 65k
Here's to a long life and a happy one.
A quick death and an easy one.
A pretty girl and an honest one.
A cold beer and another one!
Old 29 Jul 2009, 05:23 pm
Default Re: Install - Oil Pressure Sensor
Old 29 Jul 2009, 06:12 pm
mopar_man's Avatar
Crewin's diagram pretty much sums it up. I saw that in my service manual today. 3 steps for replacement: place drain pain under sensor, remove sensor, replace sensor. Pretty straight forward now that you know where it is.
1973 Barracuda
340/auto
Modifications: Too many.
2002 PT Cruiser
N/A 2.4L/5-speed
1989 Caprice Wagon
307/auto
Old 29 Jul 2009, 06:16 pm
Quick question. What is the secret to getting the electrical connector off the sensor. Spent 45 min. on my back & still couldn't get it off. But then im old.
Old 29 Jul 2009, 06:58 pm
mopar_man's Avatar
I can't see mine from the top but I'm assuming it has a little red safety "lock" that you'll need to slide open before you can press the tab to remove the connector.
1973 Barracuda
340/auto
2002 PT Cruiser
N/A 2.4L/5-speed
1989 Caprice Wagon
307/auto
Old 29 Jul 2009, 07:54 pm
It's not like the others that are on top of the engine.
Old 30 Jul 2009, 08:12 am
geronimo's Avatar
I haven't seen it either, but for some sensors, there's a red tab to push and then a clip that you have to press down in order to get it out. Can't think of the sensor I'm thinking of off the top of my head, but this one might be the same.
Old 30 Jul 2009, 08:13 am
geronimo's Avatar
Also... thank you Crewzin for your pictures, that helps a lot. Any idea where I could buy a fancy book with pics like that? I've got the Chilton's manual, but some of the repairs lack them pertty pictures.
Old 16 Sep 2011, 10:16 am
Thanks Crewzin for the Diagram, I'm going buy the sensor today and get my BF to replace it. I love this forum and everyone who adds in their experience and knowledge to help the rest of us.
Thanks
Babydolls2004 PT
Old 16 Sep 2011, 04:30 pm
Chromenut's Avatar
Some more info for you, from the OEM Service Manual:
The location map does mirror what Crewzin said as to connector location:
The connector that you need to pull is an ugly light green with a side-pull locking connector. I've identified the two locks, one is the side-pull in orange, and the locking tab in blue. The picture of the connector is end-on, facing into the plug itself. In the picture below, I've pasted the connector info next to the location info. The connector is what needs to be pulled off to get the switch out.
I tried to use the color green that the switch is in my examples, so you can see sort of the color of the connector on the end of the cable. Ugly as sin....
...if I only had a brain...
I would need my own forum just to list my mods!!!
Remember, a PT Cruiser is not just a car, it's a way of life!
LAUS DEO SEMPER
Check Engine Light came on - code 1188? coolvirus General Turbo Discussions 38 25 May 2011 09:01 am
Tranny She is a no-good! scottscars Stage Turbo Kits 15 16 Oct 2004 11:11 am
