Help! Timing Belt damage
Old 31 Jul 2009, 12:11 pm
Default Help! Timing Belt damage
Hi. We have a 2005 PT Cruiser (2.4 non turbo). The timing belt went while I was driving. My husband changed it. Then he found we had at least one bent valve. My question, because I'm not real car knowledgeable, is, does the entire engine need to be replaced, does the valve need to be repaired or can you get another valve from, say, a salvage yard. (Also, what the heck is the valve cover? Is that what is bent? My father-in-law has a friend who said he could repair it for around $700. I don't know if that is for one or for however many could be bad. We are trying to come up the most reasonable cost. Any suggestions would be greatly appreciated.
Thanks.
Vicki
Old 31 Jul 2009, 12:36 pm
Default Re: Help! Timing Belt damage
Here is what happened: The valves hit each other. SO which ever ones hit are your problem. The only way you can tell the extent of the damage is to take the head off. Most likely you will be able to get away with just replaceing the valve(s) and a valve job. Worst case if the head of a valve got knocked off and hit the piston top then you will need a motor. Bottom line is you won't know till it's torn down.
Old 31 Jul 2009, 02:38 pm
mopar_man's Avatar
Pretty much and even then it might not be totally obvious. I had the timing belt in my car break and I couldn't tell if everything was alright. I took the complete head to a local rebuilder and had it checked out just to make sure no valves were bent or any guides got buggered. I think it cost about $200 but I'd rather that than take the whole thing apart again to find that what looked OK turned out not to be. If you would rather skip the head check, you can get a rebuilt one on eBay for under $500: link.
1973 Barracuda
340/auto
Modifications: Too many.
2002 PT Cruiser
N/A 2.4L/5-speed
1989 Caprice Wagon
307/auto
Another possible timing belt question PTBlue_2002 Tech & Performance Forum 2 16 Jun 2009 06:51 am
Timing Belt 2001 Limited 2.4L CharliePT Tech & Performance Forum 2 08 Mar 2009 10:26 pm
loose timing belt and gears not moving - urgently need help pls. lanies_ptcruiser02 Tech & Performance Forum 12 12 Aug 2008 05:36 am
Another timing belt question thread :) ??? Ctown General PT Cruiser Discussions 4 24 May 2005 08:50 am
