2005 2.4 Turbo stalls sets code P2305
Old 01 Aug 2009, 03:06 pm
Default 2005 2.4 Turbo stalls sets code P2305
My daughters 2005 Pt Cruiser Convertible Touring Edition has the 2.4 Turbo engine and automatic trans with 92000 miles on it. Two weeks ago it stalled on her and restarted fine and check engine light came on and stayed on. I was able to pull code #P2305 with my code reader. Alldata info was check plug wires and plugs for cracks or carbon tracking. I installed new Autolite wires and Platinum plugs and cleared codes. I noticed her car was turning over slow and I load tested the battery and it failed. I replaced the battery and sent her back out into the world. It ran great for two weeks no problems and yesterday it cut off twice. She said one time the rpm's shot up to 4500 for an instance and dropped back to normal. When it cuts off it will start back up no problem. It cut off once at traffic light and twice driving down the road. It is not setting any codes this time and check engine light did not come on. Any idea's where to look would be appreciated.
Old 01 Aug 2009, 03:17 pm
Default Re: 2005 2.4 Turbo stalls sets code P2305
Your not alone. Read this and see if it helps:
Ignition coil problem...maybe?
Old 02 Aug 2009, 10:25 am
Ok I will try a coil capacitor. It must be a dealer item as I can't find it on local auto parts store sites. Below are possible causes for setting code P2305 from a pay site. I'm assuming that if this capacitor quits it kills the coil.
WHEN MONITORED
Engine Running.
SET CONDITION
If PCM detects that the secondary ignition burn time is incorrect or not present an error is detected. One Trip Fault
POSSIBLE CAUSES
* Intermittent condition
* Spark plug
* Ignition wire
* Ignition coil operation
* Ignition coil control circuit open
* coil control circuit shorted to ground
* PCM
* (A142) ASD relay output circuit
* Ignition coil
Old 29 Aug 2009, 06:46 am
After my last post the PT Cruiser finally set a code after stalling for the Crankshaft sensor. I replaced it 3 weeks ago and it it is still running great with no stalling out. Thanks for your help.
Old 29 Aug 2009, 09:51 am
Thanks for returning and letting us know what worked.
2004 PT GT Stalls with P0340 code ron2004gt General Turbo Discussions 18 17 Apr 2011 06:46 pm
2005 GT TURBO IDLE miamipidan General Turbo Discussions 10 02 Mar 2008 07:32 pm
2005 GT Turbo Convertible Airbags and speakers mixedplate PT Cruiser Convertible Forum 3 07 Dec 2007 09:21 pm
P0325 Engine Error Code on 2003 PT Turbo intim3 General Turbo Discussions 0 12 Aug 2007 08:06 pm
Chrysler to Offer New Cheaper GT Turbo skylight PT Cruiser News and Rumors 19 12 Jun 2003 02:04 pm
