PT Cruiser Forum Car Videos
Jeep Parts | Car Rims
E-Brake
Old 27 Mar 2002, 09:16 pm
ptbruizer02 ptbruizer02 is offline
Send a message via AIM to ptbruizer02
Default E-Brake
I installed a injen cool air intake and for some reason whenever i step on it my ebrake lite comes on. Does anyone know about this.
Old 27 Mar 2002, 10:51 pm
Nutt Nutt is offline
Send a message via AIM to Nutt
I installed the injen on mine and don't have that problem. Its possible your E-brake lever is not going down all the way. Its just a little switch that activates the light when pressed on by your lever. It shouldn't be anywhere near your intake.
Old 28 Mar 2002, 04:24 am
iggman iggman is offline
You are low on brake fluid. Now that you got your new intake, your car has a bit more pickup. This causes the brake fluid in the reservoir to surge back and tells the sensor that you are low on fluid, therefore triggering the light to go on. Top off your fluids and you'll be fine.
Old 01 Apr 2002, 06:35 pm
Mel Mel is offline
Iggman stated the most probable cause for your flashing brake light during acceleration but keep something else in mind. When you check your brake fluid, if it's low, where did it go? Barring leaks, your brake pads and/or shoes, if you have rear drum brakes, are probably getting low. There have been quite a few entries on the forums where people have complained that their pads have worn down to the point of ruining the rotors with no previous sounds or warnings.....until the metal to metal grinding. Since you're noticing the flashing brake light, it's probably past time to check your brakes, and be sure to check all of them. At times, the actuator in only one of the wheels may stick and cause premature wear from the pads dragging on the rotor. If the pads are 1/8 inch thick or less, replace them.
Hope my $.02 helps.
Mel in Gilroy
Garlic Capitol of the World
Cranberry 28G, Loaded
Old 20 Jan 2004, 11:19 am
Alan Welch Alan Welch is offline
I was having a similar problem, brake light flashes on during acceleration, so I did a search of the forums here. Thank you all for shedding some light on this issue.
YerPalAl
Why . . . yes, this IS a PT Cruiser.
Old 20 Jan 2004, 11:58 am
IRPT IRPT is offline
Mel, welcome to the forum and thanks for the good advice.
2002 Inferno Red PT Limited
Mercedes Wiki
Old 20 Jan 2004, 08:38 pm
bobs turbo pt bobs turbo pt is offline
welcome mel, good info!!
Old 20 Jan 2004, 09:40 pm
Hooligan Hooligan is offline
Mel, [^] Welcome to the forum. You give good info!!!
Old 21 Jan 2004, 12:40 am
skeeter1620 skeeter1620 is offline
welcome mel
2003 Dream cruiser 2 #1434
mopar bov and k&n drop in filter ,billet shorty antenna, silencers removed, custom painted rear shelf that says\"Dream Cruiser II\"and maybe, doubtfully soon------stage 1
Old 21 Jan 2004, 01:10 pm
KingKole02 KingKole02 is offline
Welcome to the forum Mel,
Thank you thank you.
KingKole02
SW Florida PT Cruisers
Just Cruisin, 03 N/A auto. TE Steel Blue w/ pearl coat & chrome package. Too many extras to list, see pics
For cruiser pics go to:
http://ptcw.truckmoxie.com/mygallery.ten?id=3464
http://smg.photobucket.com/albums/v8...0in%20my%20PT/
For my personal page, visit
http://www.kingkole02.com
http://random-input.blogspot.com
http://www.ptcruiserweekly.com
www.jumpsometravel.com Travel Everywhere! - Owner
vB code is On
Parking Brake Light upon Acceleration JohnM Tech & Performance Forum 5 27 Jan 2006 09:07 am
Brake kits for the Pt Gt from Moparsupercenter.com JEFF@RHJEEP Vendors & Buyers Forum 0 23 Apr 2005 01:07 pm
Update on Brake Shims jmack General PT Cruiser Discussions 2 12 Apr 2005 08:10 am
Parking brake light coming on CHROMEDCRUISER Tech & Performance Forum 8 06 Dec 2004 10:11 pm
Brake Dust and Tar turbomangt The Detail Shop 3 27 May 2004 01:07 pm
  Credit Cards | Flights | Mortgages | Mobile Phones | Flights
