2002 - upgrade to 2003 auto shifter lever
Old 04 Aug 2009, 01:05 pm
ADR's Avatar
ADR ADR is offline
Default 2002 - upgrade to 2003 auto shifter lever
Basically, I want a chrome-stem ball-style shifter from the newer PT's in my 2002.
I've found an assembly on E-bay from a 2003 that I could swap in, but am hoping there is a faster/cheaper solution. Can anyone with a new shifter give some insight about how the stem and knob mount? Is replacing the whole gear-change assembly required??
I don't really like the looks of this:
I also found the Kustom Kruzr knob:
But prefer the stock look of the Chrysler part.
Any other options??
Thanks
Last edited by ADR; 04 Aug 2009 at 01:27 pm. Reason: I guess this should be moved to the "Interior Accessories Forum"
Old 05 Aug 2009, 02:11 pm
ADR's Avatar
ADR ADR is offline
Default Re: 2002 - upgrade to 2003 auto shifter lever
I just ordered the assembly from Ebay.
I'll keep you posted on how the install goes.
Old 05 Aug 2009, 07:46 pm
geronimo's Avatar
which assembly did you order? the stock white ball?
2003 Touring Edition. 65k
Here's to a long life and a happy one.
A quick death and an easy one.
A pretty girl and an honest one.
A cold beer and another one!
Old 06 Aug 2009, 01:21 am
ADR's Avatar
ADR ADR is offline
It seems to be from a 2003 turbo.
Old 06 Aug 2009, 08:09 am
geronimo's Avatar
Very nice. Didn't know they changed shifters from n/a to turbo. Good luck on on the switch.
Old 14 Aug 2009, 01:48 pm
ADR's Avatar
ADR ADR is offline
Default UPDATE
I received the shifter assembly from Ebay today. I failed to notice in the picture that this is an AUTOSTICK. So obviously, the gear selection window, electronics and mechanics of the lever are different than the 2002 normal auto gate.
I've dissassembled the AUTOSTICK to find how the chrome shaft is attached to the linkage. I hope to simply remove the chrome shaft from the 2003 linkage and replace it into my 2002 linkage without too much trouble.
This leaves the the illuminated gear selection window. The AUTOSTICK has a leather shift boot that I would like to keep. However, I'm afraid that my 2002 molded plastic gate cover also slides the gear indicator. Once the cover is removed, the gear indicator may no longer work.
Next step is to remove the center console to find out how much of my 2002 shift linkage matches the 2003. I may need to mod some parts to make this work....
2002 Limited Edition
Old 15 Aug 2009, 08:35 am
I performed this swap and wrote the guide with photos at www.ptdiy.net about 5 years ago. The part numbers for everthing needed is posted in the guide. The parts were ordered from Chrysler and are not very costly.
Old 15 Aug 2009, 11:00 am
ADR's Avatar
ADR ADR is offline
Thanks for the clue
Is the guide posted in the Pit Area? It seems every link I click requires a password
Old 15 Aug 2009, 12:16 pm
Originally Posted by ADR View Post
Thanks for the clue
I think you have to join. It is a good site, MX-5 wrote and donated many of the "fixes" before they started charging to join, hope he is getting "residuals", Yeah, right!!!
Need Stock ECU Computer for 2003 GT Auto nitrouspt Stage Turbo Kits 0 02 Jun 2009 12:23 pm
Auto Shifter Knob - PTKNOB03 Zoowackery Interior Accessories Forum 2 04 Oct 2008 10:39 am
Auto Trans shifter quit on me.... BumperBob Tech & Performance Forum 10 30 May 2007 06:27 am
Chrome Shifter For 2003 & Up Auto Sticks ptcruzin42 Classifieds: For Sale/Trade 0 07 Aug 2005 08:20 pm
Shifter and cable problems 2003 PT lonehorse Tech & Performance Forum 1 05 May 2004 02:55 pm
