Problems with new style tensioner
Old 04 Aug 2009, 10:52 pm
Default Problems with new style tensioner
Hi Guys....
My first PT Cruiser (2001) and I've dived into a timing belt replacement. I purchased all the parts for the new style timing belt tensioner and have done ok getting things off. But as I'm to the point of getting the timing belt installed....I just cannot get the new tensioner held in a position where it's not putting tension on the belt...resulting in the fact that I cannot get the belt in place.
Here's a question or two...
1) The tensioner came from the dealer already mounted on the little mounting arm. Is there any adjustment that I need to do? Or can I just go ahead an bolt the assembly to the block (which is what I did). The installation instructions say I need to install the belt and then make sure the end of the spring is visible within the noched-out marks to assure proper pressure on the belt.
2) Is there a way to lock the tensioner into the relaxed position so that I can get the belt into place?....and then release the tensioner to tighten against the belt?
Thanks for the help!
Old 05 Aug 2009, 09:21 am
geronimo's Avatar
Default Re: Problems with new style tensioner
Make sure it's installed properly. I spent 2 hours trying to fit the belt on only to realize it was on backwards
Just reread the post, there shouldn't be any adjustments to the pulley, just bolt on. I'm not sure about the tension relaxer.
However, there's a bolt that you get to from the top that you should have loosened to get the belts off. You could try loosening that a little bit more.
2003 Touring Edition. 65k
Here's to a long life and a happy one.
A quick death and an easy one.
A pretty girl and an honest one.
A cold beer and another one!
Old 05 Aug 2009, 10:59 am
mopar_man's Avatar
Does your tensioner look like this?
Or this (the one on the right)?
1973 Barracuda
340/auto
Modifications: Too many.
2002 PT Cruiser
N/A 2.4L/5-speed
1989 Caprice Wagon
307/auto
Old 05 Aug 2009, 11:54 am
Yes...the tensioner is the one in the top picture. I think I know the problem....
I pulled the tensioner out of the package and just bolted it onto the block (via the bolt hole at the one end of the arm). I did not loosen the bolt that holds the tensioner to the arm. By loosing the center bolt...that will allow the tensioner to move back and give me the room to allow the belt to be installed.
I'm not clear on how to assure that I have the proper tension on it before tightening the center bolt. I think I use a 1/4 rachet and rotate the plate counter clockwise until the spring is visible in the alignment marks on the plate...and then tighten the center bolt. Is that correct?
Like I said...my mistake was thinking that this tensioner was essentially spring loaded and the center bolt should not be loosened as part of the install.
Thanks!
Old 05 Aug 2009, 12:30 pm
mopar_man's Avatar
I'm not familiar with that tensioner but your logic seems right. Is there instructions included with how to insure proper tension?
1973 Barracuda
340/auto
2002 PT Cruiser
N/A 2.4L/5-speed
1989 Caprice Wagon
307/auto
Old 05 Aug 2009, 04:24 pm
I'm following the instructions in the "2003 PT Cruiser Service Manual"...but it's still not 100% clear.
Old 05 Aug 2009, 07:44 pm
geronimo's Avatar
torque specifications are 200 in-lbs for the tensioner pulley bolt, 45 ft-lbs for the tensioner bolt on 01&02's, and 220 in-lbs for 03 models. Be careful with the conversions, I broke a ton of screws using ft-lbs when it was suppose to be in in-lbs.
Old 06 Aug 2009, 09:00 am
Well...I finally got the timing belt on. But I had to take the bolt out of the tensioner and remove it....then I put the timing belt into place....and then pushed the tensioner against the belt by hand and fumbled around until I could thread the center bolt on the tensioner. There was just no way I could slip that timing belt into place with the tensioner pulley installed first.
I've changed timing belts on various model front-wheel drive cars but this PT Cruiser job was by far the most difficult because of the clearance issues.
Old 06 Aug 2009, 09:12 am
geronimo's Avatar
Yeah, it's a b*&#! Suppose that's why they're rated for 100k, shouldn't have to do it again for a long long time. Congrats
Old 06 Aug 2009, 10:58 am
mopar_man's Avatar
Good to hear you got it on. I struggled with mine too. I had to remove and replace it 3 times because the cam gears moved putting it on. It didn't look like it when the belt was on but after rotating the engine a couple times, the marks didn't line up.
You replaced your water pump while you were in there too didn't you?
1973 Barracuda
340/auto
2002 PT Cruiser
N/A 2.4L/5-speed
1989 Caprice Wagon
307/auto
Timing belt tensioner Jeepertim Tech & Performance Forum 9 25 Nov 2011 12:39 pm
2002 PT Intermittent Starting Problems, Very Long, Goes Back 3 Years BeBeCroozer Tech & Performance Forum 21 11 Jul 2011 09:30 am
Belt tensioner love bandit2 General PT Cruiser Discussions 6 12 Jul 2009 02:00 am
Constant 05 PT Problems - what's the deal? TEAMCATLOOK Tech & Performance Forum 4 12 Jun 2008 05:58 pm
'02 Cruiser with lots of problems :( slpknt2886 Tech & Performance Forum 4 07 Aug 2007 02:17 pm
