The manual says the a/c system should be discharged before replacing either low or high switches. Is this really neccessary?
66CUDA |
NO, for the Cycling switch on the accumulator. That just unscrews without a loss but watch out for the small O ring underneath. It squashes and breaks easily.
I found this on the high pressure switch. Apparently you don't loose much coolant either but there is cautions. WikiAnswers - When installing new ac high pressure switch o ring blows from pressure release. how do i fix this problems
Any tips on removing them w/o damaging them. Thx, 66CUDA 66CUDA |
Like Crewzin showed you in the picture,it is most likely the low press switch so you need to try and locate one and simply unscrew it quick and put the new one on.I am telling you mine did the same thing and when i put the new switch on my problems were solved.You will just have to call around because the switch is on backorder but i was lucky and found one in which i had to take an hour drive to go get.There is almost 1200 orders already for the low pressure switch that the guy at the dealer showed me and 2300 on back order so you can tell this switch is a problem for a lot of people.Chrysler is supposed to get them on August 14 i was told,so you may have to wait a few more days,good luck.
Another thing to check is the plug-socket where the fan plugs into the wiring harness.. They sometimes develop a bad connection and then burn up/short out..when this happens it can cause a overload in the fan ciruit..Because of the overload the fan relay will cycle on/off . I had this happen to mine,the symptoms were the same as yours..I just cut out the plug and wired it in direct..Be careful and don't get the wires mixed up..Mine must have been a aftermarket fan as all leads from the motor are the same color.Keep us posted on the results.....
One of my pet peeves is people not posting results.........
This Black Thing Keeps Chasing Me ![]() YES ! That is a Ron Paul for President Sticker.. ![]() Growing OLD is Natural - Growing UP is Optional It's NEVER too late to have a Happy Childhood ![]() Ed Sidders , Lake-O The-Pines , Northeast Texas |
Where is the cooling fan circuit relay on a 2006 PT?
I have no idea , on my 01 it is in the fuse box below the master cylinder...
Fuse box is still there but the relays were placed elsewhere. The sticky post for '06 PT's shows it in trhe fuse box like your '01 but its wrong.
66CUDA |
| Air conditioning is cold, but stops blowing | Beej | Tech & Performance Forum | 9 | 13 Dec 2010 01:10 pm |
| Air is blowing warm? | enriquesoteloPT4 | General PT Cruiser Discussions | 2 | 21 Jun 2009 04:15 am |
