RESULTS ARE IN!!!!!
Well Sunday afternoon I disconnected the battery for a few minutes to reset the PCM since that seemed like the easiest place to start. I also checked the connections and disconnected then connected the low press. switch. Today I drove her around that day for about 30 miles. Today its hot like Mars - 95* and humid. I drove about 15 minutes from the gym and let her idle for 10 minutes. The cooling fan was on the whole time and she was around 35lbs of pressure during the idling. I shut her down for about 90 minutes and let her idle again and the fan was running and the pressure was 55lbs blowing cold air. So far it looks like the PCM reset did the trick, only time will tell. Comments please. 66CUDA |
This is exactly what happened to my daughter's 07 PT base. And Slarty is right on the money - the high speed fan had to be replaced. Fortunately my mechanic found an aftermarket for nearly half the price of the OEM. Does this tell you something Chrysler - there is an aftermarket assembly for a part that for most vehicles only come from a dealer?? To top that, the OEM was very high to find (another indicator that this problem is WAY too common) and so is the aftermarket (they keep selling them out). With labor my replacement costs a little over $300. But since Obama told Chrysler to stiff their suppliers of the money they legitimately owed them, it's getting harder to get parts.
2008 Turbo Vert "The trouble with quotes on the Internet is that you can never know if they are genuine." -- Ben Franklin, 1706-1790 |
Did it turn out to be the cooling fan itself or the condense rcooling fan motor?
If I test the fan and it works with 12v then that would rule out both scenarios? 66CUDA |
Well its day 3 since the PCM reset and connection checks and the high speed fan is working appropiately. I got a funny feeling that the low speed press. sensor was not in full contact with the bottom piece because it came off rather easily. Any connection I ever remove was always screwed on tight or a real @#(_*_ IN THE !@! to removed. It snapped back in rather nicely. Time will tell....Thx for all the insight...
..Keep ya posted!...![]() (by the way, where is the fan blower motor located?) 66CUDA |
Uh, right in the middle of the fan itself. Round about 9 inches in diameter, or are you talking about the inside-the-car blower motor? If you are, it's part of the HVAC system in the dash....
![]() ...just CREWZIN along! ® . . . PT Cruiser Links Moderator ![]() 2000 PT. Original Owner, 110,000 miles MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a Garage. Visit My Home Page www.CREWZIN.com Last edited by CREWZIN; 11 Aug 2009 at 07:18 pm. |
Cooling fan motor....by your description it must be only about 2" thick in order to fit in between the fan and radiator. I can't see it on my '06, your '01 must be different if its that easy to see.
66CUDA |
I thought they are all about the same. Only the wiring is different.
Here's one with dual wiring connection. Not sure if it's 06-09 or for the GT.
![]() ...just CREWZIN along! ® . . . PT Cruiser Links Moderator ![]() 2000 PT. Original Owner, 110,000 miles MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a Garage. Visit My Home Page www.CREWZIN.com Last edited by CREWZIN; 11 Aug 2009 at 07:36 pm. |
| Air conditioning is cold, but stops blowing | Beej | Tech & Performance Forum | 9 | 13 Dec 2010 01:10 pm |
| Air is blowing warm? | enriquesoteloPT4 | General PT Cruiser Discussions | 2 | 21 Jun 2009 04:15 am |
