A/C blowing warm then cold idling & overcharged!!!
  #31 (permalink)
Old 11 Aug 2009, 09:08 pm
1quick4dr's Avatar
Default Re: A/C blowing warm then cold idling & overcharged!!!
i dont know if anyone needs one but i have a brand new AC compressor . om me for details . thanks
  #32 (permalink)
Old 12 Aug 2009, 08:39 pm
Oh well, back to "square one" , everyone knew but me that I was dreaming thinking it was going to be that easy. Hopefully tomorrow I can finally test the fan with 12V. And the low press. switch is on backordered as mentioned earlier.
66CUDA
  #33 (permalink)
Old 13 Aug 2009, 07:22 pm
03hothemi's Avatar
66CUDA
Never can be that easy...can it?
Oh how I long for the days of 450 hp v8's, carbs, distributors, no PCM's and no emissions guidelines...
2005 PTC Limited N/A- All Stock...for now
2003 Hemi Ram - TMR, Flows, Killed the Cat with mechanical O2 sim, K & N, no hat, Taylor Shorty Wires, Tow Pkg
  #34 (permalink)
Old 13 Aug 2009, 07:36 pm
No emissions guidelines ? You showing your age now. I can remember helping a stranded motorist by using a matchbook cover to gap the points.
  #35 (permalink)
Old 13 Aug 2009, 07:52 pm
What's even more frustrating is that I can't do any troubleshooting or repairs until the poison ivy on my hands & arms gets better. .... If my cooling fan passes the jumper cable test where do I look next? I still can't find the cooling fan circuit relays.
66CUDA
  #36 (permalink)
Old 13 Aug 2009, 08:10 pm
66CUDA
Haven't seen it myself because they changed in 06 but someone else on this forum said the relay is on the fan shroud.
  #37 (permalink)
Old 13 Aug 2009, 08:28 pm
03hothemi's Avatar
LOL! I've got a 79 Ford pickup in the driveway that will hopefully some day be able to cure my hankerin' for power and pure gas guzzlin'.
66CUDA
IIRC, On my 05 LE, the relays are in the under hood fuse box...not sure on an 06
  #38 (permalink)
Old 13 Aug 2009, 08:33 pm
Dollar bill worked also!!
  #39 (permalink)
Old 13 Aug 2009, 08:35 pm
All relays are on the firewall under the hood. No relays or fuses by drivers leg as they are on '01 - '05's.
  #40 (permalink)
Old 13 Aug 2009, 08:37 pm
Yes, the high and low speed relays for the fan are in the PDC in the engine compartment for the 00-05 cruisers but everything changed in 06. I have the complete list of everything that's in the new fuse box for the 06+ plus cruisers and unless they changed the name of the "relay", there's no fuse or relay for the fan in there. When I searched this forum, as I said above, the answer was that the relay (they only mentioned one) was on/attached to the fan shroud and that's a contradiction to what hooligan has said about the firewall.
Air conditioning is cold, but stops blowing Beej Tech & Performance Forum 9 13 Dec 2010 01:10 pm
Air is blowing warm? enriquesoteloPT4 General PT Cruiser Discussions 2 21 Jun 2009 04:15 am
