Bosch 02 sensor not working
Old 15 Aug 2009, 09:12 pm
Default Bosch 02 sensor not working
My wife's cruiser was giving the bank 1 sensor 1 code, so we had our neighbor, who is a Honda mechanic, put in a Bosch sensor from NAPA. So, it was professionally replaced. Well, after a month, we're getting the code again!!!!!
Her inspection is due in two weeks. I saw one post on here saying a non-Chrysler 02 sensor may give issues like this. ANyone else have a similar problem?
Jason
Old 16 Aug 2009, 08:48 am
Default Re: Bosch 02 sensor not working
Jason,
There's some confusion on a couple of write-ups that I saw about which 02 sensor needs replacing with the codes that pop up. I take it you replaced the sensor that's right in back of the engine rather than the sensor by the CAT.
There's really only 2 things to do. Replace the one you already did with a Chrysler dealer sensor, or try a new sensor downstream by the CAT.
If your anywhere near higher mileage, it won't hurt to replace both sensors anyway because if one failed, the other can't be far behind.
I saw where aftermarket sensors for the Camshaft and Crankshaft didn't work and had to be replaced by Chrysler sensors but don't remember seeing anything bad about the 02 sensors. I bought mine from NAPA 6 months ago and replaced both 02 sensors even though I had no code, just for preventative maintenance at 95,000 miles. They're working fine.
Old 16 Aug 2009, 05:37 pm
03hothemi's Avatar
I know bosch sensors produce similar bad results on Dodge pickups as well.
2005 PTC Limited N/A- All Stock...for now
2003 Hemi Ram - TMR, Flows, Killed the Cat with mechanical O2 sim, K & N, no hat, Taylor Shorty Wires, Tow Pkg
Old 17 Aug 2009, 05:40 am
Travis2k7's Avatar
To each his own I say.
I replaced my downstream O2 sensor with a Bosch back in April... 5000 miles so far and the code hasn't come back.
2006 Limited, Auto, 90k miles
Old 30 Sep 2010, 01:19 pm
Now--again-- you have replied to a post that is over a year old. Are you just screwing with us or did you miss your last round of meds?
2004 N/A atx --but-- Kenne Bell pcm, cat delete, turbo composite intake, Snow water/meth/sumpn., K&N Apollo/ram air, hyper-ground, port/polish/shave, Crane 12's, Rhoads/Eaton lifters, DCR dog whistle, Hedman ceramic 4-2-1, Zoom cam gears, Braille battery, MSD coil/one-off coil heat guard, Nology with two PC-10's, Silverstone R4YS plugs, toluene, AEM afr, Autometer vac., Aeroforce Interceptor, 180 t-stat, Gold Line drop, 2.5" exhaust, Aero 2.5" stainless muffler, two Aero stainless resonators, Amsoil Z-ROD 10w30/zinc, big filter mod with Amsoil EAO15 oil filter, Amsoil ATF and some "eye candy"
Old 30 Sep 2010, 02:44 pm
Prince, our PT's do not like aftermarket sensors, use OEM!!!
A/C not working dexadel Tech & Performance Forum 70 14 Jul 2011 06:53 am
Changed battery now 6-cd player not working. ron2004gt General PT Cruiser Discussions 13 08 Sep 2009 05:18 pm
2006 - Replaced Fan - Comperssor Not Working wbwalsh General PT Cruiser Discussions 5 23 Jul 2009 02:33 pm
Bosch Plugs & Wires? JsMidnightblue Tech & Performance Forum 2 02 May 2005 09:52 pm
