So WHY is my car quicker under partial acceleration off the line?
Old 16 Aug 2009, 12:22 pm
Default So WHY is my car quicker under partial acceleration off the line?
My car is officially quicker accelerating under partial throttle than full throttle from a stop. Why the hell is this?? I've done a lot of monitoring and testing and it's certain.
Now, if I'm moving then it's DEF quicker under full throttle.
Silver 2002 pt cruiser touring edition, auto, dark ass tint, 89k miles... shift burp mod, SRI
2005 civic ex special edition, 5spd, fully loaded, 40k miles
I have a wide-band o2 sensor for sale!! PM ME!!
Old 16 Aug 2009, 12:31 pm
Default Re: So WHY is my car quicker under partial acceleration off the line?
Do you have an intake or K&N filter? I bet either one would help.
Does it miss or skip?
Old 16 Aug 2009, 12:39 pm
Because the PCM limits timing advance to 23 degrees in open loop; above 85% throttle. Up to 85%, you can get as much as 37 degrees advance.
Also, intake air vacuum is higher with the throttle plate partially open. Wide open throttle lowers the intake vacuum, and thus lowers air velocity until the RPMs increase to compensate.
Old 16 Aug 2009, 01:37 pm
Yep I've got an aem short ram intake. The car did this before and after the intake.
I've never in my life heard of a car thats slower in partial throttle than full throttle lol. Very good info though. How can this be altered? How can the PCM be programmed to allow more timing? I bet that would alter the performance of this car EXPONENTIALLY if that could be fixed.
Old 16 Aug 2009, 04:45 pm
wheelgarage's Avatar
Alteration to the intake with a combination of computer work. Velocity, pressure, timing, etc...The list can go on. On one of my old race bike (RVF400), it had staggared velocity stacks to provide an even acceleration force. This was needed to keep the V4 from choking from low rpm acceleration. In order to fix that issue will take some experimentaion. Not unless someone figured it out already...
The intake manifold design isn't designed to win any races.... If you can use a programmer to adjust timing. There is a good possibility to get some addition perfromance out of it. Programming the ECU itself, I haven't come across that yet for an N/A engine.
2005 Touring Black - Automagic....
H&R Cup Kit | TSW Sakata 18x8 35ET | Nankang NS-II 235/40/18 | SPC front alignment cam - rear shim | OEM Rotors | Akebono Ceramic Pads | Rebuilt Cylinder Head - Safety Valves and Guides | Felpro Head Gasket and upper rebuild kit | Fail-safe 195 degree thermostat | Mopar Waterpump...lol | 3rd radiator fan motor | Gates timing belt kit | WIX filters (oil, transmission) | Mobile 1 5w30 | Mopar ATF4 | Redline Water Wetter | K&N Drop-In
Old 16 Aug 2009, 08:49 pm
Interesting. Good information.
So the entire intake manifold is the culprit then? Hmm.
Where could I find a different, more efficient or power-producing intake manifold?
Old 17 Aug 2009, 02:32 am
chris15's Avatar
I've noticed the same thing as well, but have just become accustomed to it. Mine's an N/A '01 with a short ram intake, and it's scared me a couple times.
I live in Tampa, FL now, and traffic going into my apartment complex is a bitch (for lack of a better term). So, when I see a gap as I'm waiting in the median to turn, I go for it. A couple of times though, I've floored the PT due to the speed of oncoming traffic and I wind up sitting there, hairs on the back of neck raised, saying 'What the..?' and making sure I actually hit the accelerator with my foot, and not just the floor. :/ It sucks.
But like you'll find with most of the PCM issues with PTs, Chrysler has the parameters locked up like Fort Knox.. though someone might have a fix for it.
2001 PT Turbo - In the process of a major overhaul.. :]
2006 Cobalt SS/SC - Stage 2, 3" Exhaust, Meth and soon to come: Zex 75-shot :]
Old 17 Aug 2009, 07:00 am
^Same here... i'm at a super busy Army base, so when i see an opperunity, I seize it. And like you say, I worry GREATLY until the car reaches 3200rpm's or so. It almost feels like I pulled out into traffic and didn't hit the gas to move anywhere else.
Though, you gotta admit when the car hits about 3200rpm's that SRI sounds GREAT doesn't it??
Old 17 Aug 2009, 09:31 am
Travis2k7's Avatar
NA Cruiser and "quicker off the line" made me LOL.
2006 Limited, Auto, 90k miles
Old 17 Aug 2009, 10:27 am
Location: Belleuve, WA from Los Angeles - Road Rage specialist
No the N/A manifold is pretty good, compared to the metal turbo one. The holy grail of manifolds for these cars is the turbo plastic.
Better flow more even flow than both the N/A plastic and Turbo Metal which is also a big weight and heat holder in the engine bay.
The silver 03 GT is gone, but a Solstice has arrived. There are three more PT's to play with though
My personal thanks to veteran and novice crewbies that have offered information and how-to's they have been instrumental in taking LiquidPT from modded car to stock to live a more quiet and sedate life.
Gold line springs info oldcoach Wheels, Tires, Suspension 0 29 Apr 2009 06:42 am
NEW 2007 Cruiser had a leak in fuel line stacigw General PT Cruiser Discussions 1 20 Nov 2007 09:52 pm
FS: Schmidt Space Line 18x8,5 (Silver or Chrom) tunershop Vendors & Buyers Forum 0 10 Oct 2003 10:24 pm
