Why does my ac/heater all of a sudden feel like it's got something blocking the air?
Old 17 Aug 2009, 06:12 pm
Default Why does my ac/heater all of a sudden feel like it's got something blocking the air?
It feels and sounds like there is something blocking the air intake (sounds really muffled and the air output is severely decreased)? While driving, it randomly does this. So I pulled the glove box out and looked and couldn't see anything that would be blocking the intake.
After stopping at gas station and checking it out, I'm driving down the road and it magically fixes itself and it's super cold/fast again.
What is occuring?
Silver 2002 pt cruiser touring edition, auto, dark ass tint, 89k miles... shift burp mod, SRI
2005 civic ex special edition, 5spd, fully loaded, 40k miles
I have a wide-band o2 sensor for sale!! PM ME!!
Old 17 Aug 2009, 09:55 pm
Default Re: Why does my ac/heater all of a sudden feel like it's got something blocking the a
ICE
This Black Thing Keeps Chasing Me
YES ! That is a Ron Paul for President Sticker..
Growing OLD is Natural - Growing UP is Optional It's NEVER too late to have a Happy Childhood
Ed Sidders , Lake-O The-Pines , Northeast Texas
Old 18 Aug 2009, 05:40 am
Originally Posted by edsidders View Post
ICE
Possibly.
If you are low on freon (or whatever they use) the coils can form ice - the ice blocks air flow.
Old 18 Aug 2009, 06:50 am
...and usually it's the fault of the cycling switch (low pressure switch) on top of the accumulator. When that goes bad, the compressor never shuts off (cycles) and the "super cold air" that your talking about actually freezes the evaporator and blocks air flow.
That's only one scenario but it can happen. It did to mine. See if you can stand in front of the car with hood open and A/C on to see if the compressor is coming on/off (cycling) like it should.
Old 18 Aug 2009, 07:30 am
Thats exactly what i thought was happening. What you are saying is the ice phsyically blocks the air ways though?? Which would make sense as to why if I put the regular fan on, it still does the same thing.
What if I blast the heat when this occurs next time?
I will do what you said and see if it is cycling. Thanks man
Old 18 Aug 2009, 07:58 am
Travis2k7's Avatar
I'm not an A/C repair man and haven't had issues with my car's A/C yet, but I can say that the A/C at home started freezing up last year, and blasting the heat did little good against 3/4 of an inch of ice.
It was low on freon.
2006 Limited, Auto, 90k miles
Old 18 Aug 2009, 09:15 am
True, against 3/4 inch of ice, but usually there isn't that much in the car. Putting on the heat does help (but when it's 90 degrees outside that sucks) and even not using the A/C for awhile will let it defrost enough to work. At least that's what happened to mine.
Travis could be right about it being low also but 85_305 said it randomly does it so if it was low and caused the problem, it would always do it until the system was recharged. My thoughts anyway.
Old 18 Aug 2009, 11:00 am
Good input guys.
Ya it only does this on occasion, seems like when the ac is ran for extended periods of time it does it; ie running around going place to place w/ the ac cranked while car running. But if I only go to a few places it seems there isn't an issue.
Old 18 Aug 2009, 12:40 pm
So, the longer it's on, more likely to happen? That sounds like icing. If it works for short hops, doesn't have time o ice up & gets to melt in between....
Old 18 Aug 2009, 05:20 pm
^Yep sounds about right.
So is this natural or is it the low pressure switch?
As you get older you feel young again... Gary04GT Non-PT Discussions 4 26 Oct 2003 01:18 am
