so my boyfriend checked my coolant reservoir on my 2006 pt cruiser before going on a 2 hour drive and noticed that it was pretty much empty. he called his mechanic (who likes to cut corners, which makes me really nervous) and the mechanic said to just add water to the reservoir and it would be fine. so we filled it up with water. my car hasn't had any problems even before we added the water but i'm going on a 10 hour trip later this week and i really want to drain the water and add the mopar hoat coolant from the dealership. i asked the same mechanic if he would drain the water for me but he said i was wasting my money by putting coolant in there and draining the water. he said my car is fine with the 90% of water thats in there. is that right?? i dont know anything about cars but the idea of having almost all water where there is supposed to be coolant is making me really nervous. especially since we're going on such a long trip. help?
And he called himself a mechanic?!
A 50/50 mix is (usually) the way to go. Go buy a coolant tester from any auto-parts or big store (Wal Mart carry it) and you'll know when the mix is ok. Don't worry...It's not because you filled 90% of the over-tank with water that the mix is now 90/10. There's plenty of coolant mixture inside the block, the rad, the hoses... If you don't have enough room to add the right amount of coolant, drain/pump some "old" mix and then add PURE coolant to bring the mix back to 50/50. Don't forget that the PT needs HOAT coolant. Some may think (the so-called mechanic... ) that water is OK as coolant in hot area or summertime since there's no chance that the stuff freezes...But it's not just about anti-freezing...The additives in the coolant are there to also prevent boiling, lime, rust and so on. Hard water isn't good with metallic parts you know. Adding water is OK for a short period if you have nothing else to put in it, as an emergency solution though. It's better than seizing your engine. Oh...a free advice...NEVER let this "mechanic" coming closer than 100' from your PT. If he wants to admire it, send him a picture... |
he's not a professional mechanic. he's just a guy that fixes cars who lives in the neighborhood. he's also very lazy which is why i dont trust a word he says (hence coming on here instead lol). my boyfriend checked my radiator and it was full of coolant. only the reservoir was empty. there was only an inch or so of pinkish red coolant and then my boyfriend added water so that it was in between the "add more" line and the "full" line (i can't remember the exact wording but you get the point). it was the water at the air/water pump they have at gas stations. i read in the manual that it is supposed to be distilled water so i told my bf to go buy a bottle of water to put in but he said i was being overly cautious and disregarded my suggestion. i knew i shouldnt have listened to him
![]() so basically i need to drain it and add the hoat coolant like i thought correct? how many gallons of coolant will i need to buy in order to refill my radiator and my reservoir? p.s. thank you guys soooo much for the help! this is my first car and i dont trust ANYONE so i'm glad to have found somewhere to turn for advice |
Like one of the above post suggested, get a coolant tester at a store. When you check it you'll probably find that a quart or so of HOAT will bring it to the correct mix.
![]() 2008 Silver Steel Metallic, Touring, NA, Sirius; Chromed door handles; lower grille; fog light surrounds; chrome front & rear bumpers strips; Airaid air filter; Bassani duals; Modesty Cover; Autolite AP5263 Platinum Plugs (.040); Crane Plug Wires; NAPA Ceramic pads; Blane hood struts; PTeazer Gas, Brake & Foot Rest Pedals, '05 Rear Step Pad, Stainless Door Sills, Llumar tint, "A" Piller chrome; APC Strut Bar |
ok does it matter that i didnt use distilled water though? thats why i thought i should still drain it. also, where do you buy HOAT coolant? can you only buy it at chrysler? i've checked autozone and pep boys without any luck. in fact pep boys told me to use the universal dexcool one. luckily i refused to let my bf buy it until i was 100% that was the right stuff. now i know it definitely isnt. |
Depends how much water was added.
If it was a quart or less, I wouldn't sweat it. In supermarket, buy a gallon of distilled water (for steam irons) and keep it in your car in case you have a need for more. What state are you in? If winters aren't severe, a little extra water won't hurt.
i'm in california so winters arent too bad. it gets a little icy sometimes (like frost on the windshield), but it never snows or anything Last edited by pineapple; 18 Aug 2009 at 08:19 pm. |
he stuck a hose in (it was one of the ones from the gas station) so i'm a little clueless. from what you said i would guess he put in a little over a quart. so i should drain it?
| coolant question | sandylolee | Turbo Performance | 2 | 10 Jun 2009 08:25 am |
| Coolant Problem | DIYPTGUY | Tech & Performance Forum | 12 | 04 May 2009 03:25 pm |
| Luggage Rack question and trailer hitch question | Patrick_Dickey | General PT Cruiser Discussions | 5 | 26 Apr 2009 09:19 pm |
| Leaking coolant line | TripleJackInGA | General Turbo Discussions | 0 | 03 Oct 2003 10:00 pm |
| Coolant drain | Chz | Stage Turbo Kits | 6 | 19 Aug 2003 02:58 pm |
